Rattle @ Startup Revisited
unless hydrolic pressure works on the intake cam for the Variable Valve Timing and the lack of pressure makes the intake cam give slack to the chain between the two cams and it bounces off the top of the Valve cover????
If the chain tensioner detent spring is faulty it may allow the tension to back off the chain as the oil pressure falls.
It took awhile but I did get a call from MB Canada and now must wait to hear from a Technician about my Rattle. I do want to know what the TSB says and hope I get an answer from them!
new parts are green color coded
PN#- 271 050 13 47 (intake), 217 050 11 47 (exhuast, 271 050 01 71 (2- center bolts).
Came out Oct 2004, revised Juy 2005 with new part numbers
It only pays like 3 hrs, so that may have something to do with the tech not hearing it!!
Where are you in Ontario? I started with MB in Toronto, at the old Yorkville store, and I know a lot of the guys have scattered, maybe a phone call can help you get your adjuster replaced..
I know this engine has been used for some years now.
By the way, My C230 only has 19,000 kilometers and has had 4 oil changes so no sludge build. I never ever just drove it short distances.
I have been thinking about this and wonder, what next?? My dealer says to bring my car in and leave it so they can hear my rattle. They also say they have done the TSB on the Cam Adjuster and are not sure what would cause the noise. So if they hear it, what will they do? I expect nothing. The top end of the engine is bleeding down. This happens to some car I am sure but fuuny thing is it didn't do it the first year of ownership and only did it on rare occasion the second and third year. Is there a valve that might be getting weak or something causeing the leak down or is it the 0W40 oil being so thin that it is getting away down to the oil pan. Synthetic oil is slippery stuff and I would think a 5W 40 or maybe a 5W50 might help stop it from bleeding away. Mobil 1 now has a 5W50 available that meets MB 229.3 specs. and am thinking of trying it. Anybody have any ideas?? Any Tech guys have any experience with this problem on the 2.3 L kompressor???
Once out of warranty you can use the oil of choice and bleed down is not going away with an oil as thin as 0w40. MB must have made some mistakes in the design of the engine and we are stuck with it until we buy our next car or should I say our Toyota!!
My car was serviced with Castrol Magnatec 10/40W all it's life from MB
I recently changed to Nulon Full Synthetic 10/40W and have a cold start rattle.
Will be going back to the magnetec
Matt
