380SL Diagnostic Challenge - Fuel System (?)
About 4000 miles ago I bought an 83 with 90K. Car looks and runs great except I have an intermittent problem - particularly when I drive the car at highway sppeds under acceleration load. Once the car is hot, and under moderate acceleration it will suddenly begin to surge and hesitiate, lose power, etc. If I let off the gas, I'm OK, but only for a minute or less when it will do it at the lowered speed also. Eventually the car becomes undriveable and/or shuts off alltogether. It will do it at city speeds too but since the accereration load is generally less, it's less often. Now when this happens, a quick restart cures the problem. The restart is immediate - no trouble at all. I go about five miles - sometimes more, sometimes less and it happens again. Restart and it's gone again. etc etc. It's gotten so I don't even pull over anymore - I just go into neutral when I feel it beginning, restart, go back into drive and voila.
Here's more info: Car starts and idles perfectly except occasionally when I first stop at a stoplight, I get a very light idle surge (from about 650 to maybe 900) nothing big and not always and when it happens - only once when I first stop. Back to the main problem: It happens more often when it's hot. Weather, ie rain and humidity appears to have no effect. Fuel tank level has no effect. I tried to remove the gas cap when symptoms exist and it has no effect. I use only premium gas and throw in a can of Jectron every other month. Everything's perfect otherwise - car never goes above 90C. Over the last 10,000 miles either I or the previous owner have: replaced fuel pump, fuel filter, catalytic converter and O2 sensor, coil, wires, plugs, alternator, battery, injectors, distributor cap, all filters, and dropped and flushed fuel tank. Car gets good mileage no leaks or smells and never smokes.
So far what I've read indicate it could be: fuel pump relay, overload protection relay, reference sensor, ignition control unit, idle control unit, idle control valve, fuel pump check valve, fuel pump vent valve, fuel pressure regulator, or the frequency valve.
Any thoughts or questions? I don't want to just throw parts at it.
Thank you in advance.
Ray
Fuel pump relay- really not an issue- it would shut the car down, not impact driveability so much
Overvoltage relay- could do it- an open circuit, that opens with heat could act like this- usually, though, when they fail, they impact cold driveabillity
Reference sensor- no- usually no- start/stall hot when they act up
Ignition control unit- probably one of the most likely- prone to fail and very, very expensive ..
Idle control anything- NOT- they do nothing when the car isn;t idling
Fuel pump check valve- not- this would impact cold start after sitting
Fuel pump vent valve- not really sure what you are talking about here
Pressure regulator- not probable- most likely to show up as a cold complaint
Frequency valve- also, not likely- its used to control lambda- so massive driveability problems don't usually come from this.
I do this- it can get waaaayyy expensive if these era cars aren;t diagnosed right- i would suggest looking for someone that knows the cars and you can trust to look at it.
Now I know there is supposed to be a certain amount of tank vacuum produced by these MB closed systems. Every other car I have ever owned makes a "whoosh" sound when I open the gas cap - this car - nothing at all. When I got it, it had a generic vented gas cap. Now since I know MB isn't vented, I replaced it with the correct non-vented MB cap. Did I make the problem worse by doing that? Also, assuming this tank vacuum / gas level clue is meaningful, what does this tell me? Have I stumbled upon something here or is this ongoing intermittent fuel starvation issue finally driven me crazy?
It's difficult for me to explain this as an ignition problem anymore. I'm also not sure how the FPR impacts this anymore either, but I'd like to make sure by getting the problem to manifest itself and then jumpering the relay. What pins do I jumper to test the FPR once and for all?
Assuming the FPR checks out OK and that the FP and filter are new, where do we go? FP check valve, FT vent valve, accumulator, screen, damper, warmup (control pressure) regulator, fuel distibutor?
If this weren't such a PIA, I might actually be fun!
Thank you all for your excellent suggestions, time, and interest in my problem.
Ray
When my ingnition module failed I had irrattic tachometer readings along with rough running during acceleration. after a week or two of this it died completely.
I think someone mentioned that perhaps the pump was weak and with plenty of gasoline on top of the pump inlet, it provided enough pressure to run the engine normally. We’ll, the guy was right!
thank you!
