rough idling on 01 ML320
Old Sep 5, 2006 | 09:35 AM
fizzle's Avatar
09 ML320, 07 BMW 335i, 03 SL500
I have an 01 ML320, with 103K miles, and unfortunately, I dont think the plug have ever been changed. So I am doing that this upcoming weekend, but was wondering if this will cure a rough idle, only while in Drive, not in Neutral. Also I am wondering exactly what tools I will need to change the plugs? I usually just use a spark plug 5/8 socket and thats it. I plan to use SeaFoam as well.
Old Sep 5, 2006 | 10:52 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be caused by plugs and/or wires.
Old Sep 6, 2006 | 09:30 AM
fizzle's Avatar
thats what i was thinking but i just wanted to make sure it wasnt anything else, like a sensor or some other electrical problem.
Old Sep 14, 2006 | 10:09 AM
fizzle's Avatar
would the MAF sensor cause this?
Old Sep 14, 2006 | 10:58 AM
sosh's Avatar
Unlikely. Whay don't you just spend a few dollars and have it diagnosed correctly.
Old Sep 14, 2006 | 03:33 PM
Hightower's Avatar
good luck with the plugs if its there first change since new! definatley will not help matters. little tip: if u can put the front on axle stands and remove the wheels then the wheel arch linings the plugs are right behind them! easy!
Old Sep 14, 2006 | 04:08 PM
fizzle's Avatar
i will if its not the plugs...figured i post a question and ask first maybe someone else has the same problem. but thanks for your knowledgable advice.
Old Sep 22, 2006 | 08:56 PM
MBTECH2003's Avatar
2000 ML 320, 2003 CBR600F4i, 99 Eclipse GSX
Do the spark plugs and see where you are at. ML's are notorious for having bad ignition coils/wires. They are also not cheap. Also note I have seen perfectly good non-mb wires/coils turn on a check engine light for a misfire.
