Service Questions
Old Sep 1, 2002 | 04:09 PM
BenzE's Avatar
2006 E500 4matic Wagon
Service Questions
My 2000 E430 4matic is alerting me that I have 1000 miles to B service. I have 54k miles on the car, and although I have the extended MB warranty to 100k miles, I realize my next FSS visit will not be covered.
If I decide to have the car worked on at someplace other than the MB Dealer, what should I expect?
The oil filter is a cartridge, right? Could any mechanic change the oil if supplied with the MB cartridge? And, what kind of oil should I use? I know synthetic is in there, but I have no idea what grade.
Also, what will happen to the service indicator warnings. Can anyone reset those?
I'm sure all of this stuff is posted already, but I'm away from home and on a 56k connection, so the searching was taking too long!
Please excuse me!
Old Sep 1, 2002 | 05:56 PM
Lynn's Avatar
The quality of work is dependent upon the knowledge, experience, and integrity of the shop and technican. You might want to look for a shop that specializes in German cars. That is no guarantee of getting quality work, but it raises the odds that they have the knowledge and experience. On the other hand I know of an independent Porsche shop that is well known in this area, but there work is crap and at least one of the owners has served prison time for fraud.
The oil fister is a cartridge and any shade tree mechanic should be able to change it. As of June 2001 the approved oils are full synthetics from Mobil1, Castrol, Valvoline, Pennzoil, and Shell. All weights are suitable for high temperatures. 0W-XX and 5W-XX weights should be used for temps under -13°F. 10W-XX can be used for temps above -4°F. When my oil was changed, the dealer used 5W-30. This should be a good weight for New Jersey.
I don't know the answer to that.
Old Sep 1, 2002 | 07:12 PM
awiner's Avatar
2003 CL55 AMG
Re: Service Questions
Yes, the FSS service reminders are eaisly reset. Read you manual for instructions.
Old Sep 2, 2002 | 07:04 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
With just a thousand miles to go to the service your dealer shoud do it for you now, before the warranty expires. My dealer did an A service for me at no charge 4000 miles early. They do have some discression in this matter.
Old Sep 7, 2002 | 02:54 AM
phungpho's Avatar
2000 E430 Desert Silver
What grade ?
I suggest the Mobil1 0-40W. It doesn't matter where you live in (Phoenix or Montreal), how fast you drive or how many times you start up the engine (cold). The 0-40W is the best combination.
Old Sep 21, 2002 | 10:39 PM
afarrar's Avatar
service
find an idependent shop that specializes in mercedes. they will be glad to do the service for you. the fss light can be reset easily, if the shop cant do it, they should try some other line of business.
use only full synthetic oil in your car, the service intervals can be quite long.
Old Sep 23, 2002 | 11:07 AM
Air Marshall Eldritch's Avatar
John Deere
I still use the dealer for oil changes. Do they put synthetic in '98 models by default or do I need to ask for it?
Old Sep 23, 2002 | 03:55 PM
Darkmann's Avatar
ML
Please excuse me!
The Mobil 1 oil viscosity is 0W40. Any competent mechanic can do the job and the FSS can be reset by anyone, following instructions in the manual - if you don't have a manual, ask and I'll post steps for you. Keep in mind that the FSS B service call is not only for an oil change. If possible, check your last B service work order to determine what was done. Most of the stuff you can do by yourself. The The oil change is easy. Go to http://www.mercedesshop.com/diy_oil_change2.htm for details. The brakes are also quite easy to do. Check http://www.mercedesshop.com/e_class_brakejob.htm for that. Other than that, check fluids - 3yrs for coolant flush, 2 yrs replace break fluid, air filter, I don't recall but do it while doing oil change, spark plugs are at 100K. That's pretty much it. And BTW, why isn't the xtended warranty taking care of FSS called service? When I inquired about purchasing xtended for mine, I was told it'll cover everything the factory covers.
Old Oct 11, 2002 | 12:14 AM
DSMIT's Avatar
1993 MERCEDES BENZ 300TE
YOU REALLY SHOULD TRY TO KEEP SERVICING AT YOU DEALER,,HE KNOWS THE CAR,HE LOOKS FOR ITEMS THAT COULD BE COVERED BY YOUR WARRENTY.
YOU DEALER KNOWS BEST,IF YOU HAVE A SERVICE ADVISOR YOU TRUST KEEP GOING TO HIM.
YOU CAN RESET THE FSS YOURSELF,,,ALTHOUGH THE DIRECTIONS IN OWNERS MANUAL DO NOT INCLUDE TO MAKE SURE DRIVERS SIDE DOOR IS SHUT,,BE SURE TO DO THAT
