W210 frequent suspension component replacement?
Old Oct 9, 2006 | 10:39 PM
jlegelis's Avatar
My W210 wagon with 45k miles just needed a driver's side ball joint (still under warranty for another month), and front sway bar links (again - ?!). My question: given the lousy roads of the northeast, can I expect a steady diet of control arms, tie rods, ball joints, etc? Was the ball joint a fluke, or typical?
Thanks,
John
'03 W210 Wagon (last of the W210's)
Old Oct 11, 2006 | 08:04 AM
vinceC's Avatar
2014 ML350 4Matic
I've got 50K on my E430 with no suspension issues whatsoever. I live in SE Virginia where the roads are a mess.
Old Oct 11, 2006 | 09:51 AM
vettdvr's Avatar
03 E500 and Corvette
I'll trade you roads for the south Louisiana After Katrina roads. I dont' think New Orleans has roads just test tracks.
Our E500 at 56k has no issues,, front end or others. Jim
Old Oct 12, 2006 | 08:09 PM
fixnbenz's Avatar
well i can tell you it is slow right now a the dealers with work. so if they are just a little loose they might have changed it just to make some money. not saying they wernt bad but just bad enough to where they could change them. the main thing i see on the 210 chassie is the ft lower control arm bushings.
Old Oct 15, 2006 | 01:54 AM
SMARTSSUCK's Avatar
I work at an MB dealer in Vancouver, Canada and can tell you I change those type of ball joints all the time, they are just poorly designed. As for control arms I have replaced many of the inner bushings on 210s but the cars usually had 100 + km on them.
