380sl o2 sensor
Old Oct 17, 2006 | 09:43 PM
jhook's Avatar
Unhappy 380sl o2 sensor
I replaced my o2 sensor and the o2 sensor light stays on continually. what does it take to reset this on the 1982 model?
thanks for any help
Old Dec 6, 2010 | 04:23 PM
landfairpack's Avatar
1982 380sl
I'm having a similar difficulty with my 82 380sl. In my case I was about to replace the o2 sensor but have not done so as the only replacements I've found would require me to splice the cable; whereas my factory 02 sensor has a cable release.
Do you know anything about the 02 sensor and the cables?
As per your question, I believe the light should turn off after 5-7 starts once the repair is made. Otherwise, I've read on a message board that you can disconnect your battery then reconnect it to reset everything. Hope that does the trick.
Old Dec 6, 2010 | 04:47 PM
ohlord's Avatar
Not a big deal
one wire o2 sensor, the sensor body is the ground to the car.
The op is probably long gone since you dug up an old old post
Old Dec 15, 2010 | 02:47 AM
svenanders's Avatar
1985 380 sl
turn off o2 light 1985 380 sl
can't seem to get the pannel out to remove the bulb help how do i
