slight vibrations
Old Nov 15, 2006 | 03:00 PM
loyalone's Avatar
Exclamation slight vibrations
I drive a E-320 2000, when starting (cold start) I get a slight vibration, until car has warmed up, then its fine...Any suggestions?
Old Nov 15, 2006 | 11:02 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Vibration while you are sitting there idling, ot when you are driving?
Old Nov 16, 2006 | 12:22 PM
loyalone's Avatar
Sorry, While sitting idle is when I feel the vibration....Its terrible but just noticeable. I 've had motor mounts done not to long ago, so I doubt thats what it is. I haven't had the sparks change since I had the car, which has been about a 1 1/2 yrs soon to be 2yrs, it has 73k on it, so I'm thinking thats what it may be.
Old Nov 17, 2006 | 12:34 AM
1via's Avatar
1996 Volvo 850 Turbo Wagon, 1991 Nissan 240sx track car
At what RPM does this happen? When the vibration stops, has the RPM changed?
Old Nov 17, 2006 | 11:43 AM
loyalone's Avatar
Not certain at what RPM it happens, RPM has not changed not that I'm aware of
It seems as if once the car starts to warm up...maybe 5 minutes or so after start up, the vibration goes away, Do you think I should be concerned??? Just never notice the vibration before.
Old Nov 20, 2006 | 04:49 PM
loyalone's Avatar
RPM stays between 5-10, but moves barely/slightly up and down but not going out of the 5-10 range.........Any thoughts?
Old Nov 20, 2006 | 09:25 PM
MBTech21's Avatar
05 ML350, 85 300D
You are barking up the right tree with the plugs- 2000 car, with what ever miles, should have had all its maintenance done by now- plugs/air/fuel filters. Injector cleaning would note be out of line. Have to make sure the basics are right first, before throwing other stuff at it.
If you still had a problem, it would be fairly easy to see with a SDS hooked to it cold, but I would bet it will be handled with the above maintenance items.
Old Nov 21, 2006 | 12:19 PM
loyalone's Avatar
Thanks for the reply MBTech21,
Question=How would I go about getting injectors cleaned? I have had the air filter replaced, but not the fuel filter, I guess I'd better have that done soon!
Also, this has nothing to do with my origenal problem....But my steering wheel seems to be a bit off centered (almost not noticeable, only to me!) Do you know what may have caused this, and if its a costly repair?
Old Nov 21, 2006 | 10:06 PM
MBTech21's Avatar
05 ML350, 85 300D
We use a canister sytem to clean them (runs off detergent and fuel)- seems to work good.
Wheel off center= alignment, toe usually off..
Old Nov 27, 2006 | 11:29 AM
loyalone's Avatar
:d
Thanks MBTech21 Good to have a tech at this forum
