coolant in transmission?
Old Nov 28, 2006 | 09:10 PM
britton's Avatar
2003 CLK 320
Took my 2003 clk320 in for service. Found out there is radiator coolant in transmission. They have mentioned to flush the tramsmission or replace it.
It is under warranty till dec. Would like any information on this.
What should I do? Thanks Britton
Old Nov 28, 2006 | 10:06 PM
C32AMG/02's Avatar
Replace it, if you don’t, over time the clutch material will peel off the clutch disc. With glycol contamination the transmission will fail.
Old Nov 29, 2006 | 01:40 AM
amgme's Avatar
07 SL550; C32 (sold)
shouldn't there be a recall for this or are they hoping warranty will run out on these cars and make the owner fork over the repair costs? obviously there's a major problem w/ the coolant in the transmission. is mb just gonna wait till it happens? no wonder they got a negative rating in consumer reports.
Old Nov 29, 2006 | 10:37 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Cause is most likely a leak in the trans cooler that must be corrected. Get a new trans if possible. You are under warranty take it to the dealer and leave it in their hands. Had this happen to me twice in a BMW.
Old Dec 2, 2006 | 09:34 AM
MBTech21's Avatar
05 ML350, 85 300D
There is a DTB on this, you will get a new radiator, as well as a new trans!!
Old Jan 20, 2007 | 04:00 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
i'm starting to fear i have contamination. once the low speed vibration is felt is it too late? would a new rad and tranny flush be of any help?
Old Jan 20, 2007 | 09:27 PM
85380SE's Avatar
85 380SE, 00 Tundra V8 SR5 4wd, 73 Pontiac Grand Ville, 69 Chevrolet Caprice, 89 Pontiac Safari
Demand a brand new transmission and radiator!
Keep us posted!
Old Jan 20, 2007 | 10:04 PM
C32AMG/02's Avatar
. Transmission coolant contamination is more prevalent with a valeo aluminum transmission fluid heat exchanger radiator, some had the logo on top of the radiator, another way to identify the radiator was how the core was mounted to the tank, I don’t remember exactly how it was mounted, I have the bulletin at my shop, I will post it this coming week.
I would send a fluid sample to http://www.blackstone-labs.com have it tested for coolant contamination. Identify the radiator, if its valeo radiator, change it, even if the sample comes back clean, that transmission cooler will eventually fail. It the transmission is contaminated with coolant yes flush the transmission, and change the filter.
That 2nd to 3rd Bump shift at light throttle is common in C32; I have seen a lot of owners post about it. If MB thinks it’s related to coolant contamination, they should pay for any repairs, even if it’s out of warranty.
Old Jan 21, 2007 | 09:29 AM
AWDman's Avatar
thanks for the input guys. this was extensively discussed on the c32 forum. the one thing i didn't know is if the tranny could be saved if flushed in time. all the folks with prob had it happen in warranty and had convertors and trannys changed. so i hope that the new rad, flush and new filter saves my *** from a beating by the wife :-)
the issue is with valeo 2002 rads, which is what's in my car. i have a brand new behr ready to go in.
sadly i'm out of warranty as of 9/06 and i don't fancy my chances of having mb pay for any repairs at this point.
my plan is as Steve said- change rad, change fluid saving some for analysis. if i have contamination i will have to see how the car feels after flush. i'm realy pissed at myself as i should have addressed this years ago. "a stich in time saves nine".
Steve- can you handle this job? you aren't too far from me. newberg? (i'm been dealing with the "stealership" up to now). like i said, i have the rad, just need to pick up the filter and tranny fluid from mb.
Old Jan 21, 2007 | 06:26 PM
babason's Avatar
C230 komp (202)
Hi AWDman,
insist that the dealer replaces the transmission and the radiator and flushes the lines. Its a recognised failing with those rads, and you should be entitled to a replacement as long as you have serviced the vehicle correctly/regularly and can prove it. Mb should either do the whole job 100% free or make a high contribution towards the cost.
mention Goodwill gesture and eskalab... to the dealer.
It shouldnt matter that you are out of warranty
babason.
Old Jan 21, 2007 | 06:52 PM
C32AMG/02's Avatar
I could not remember the brand and I thought of Behr radiators because in 1985 they had the same problem in 300Ds, coolant contamination, with aluminum radiators, in 1986 the radiators were changed to brass.
I will edit my post; we don’t what misinformation floating in cyber space.
IT sucks to grow old.
I can handle it; call me Monday, 845 567 0312. I hope I am not breaking any rules, since I am not a sponsor.
Old Jan 21, 2007 | 07:28 PM
AWDman's Avatar
Originally Posted by babason
Hi AWDman,
babason.
i will call them in the am. my SA, with whom i had a great relationship- moved to the porsche side. i was dealing with another SA who was less than cooperative and now he's gone.
plus, one look under the hood and these guys may start giving me grief.
my wife insists i'm wrong. she claims the car was like this when it came back from the stg2 and exhaust install. i started car today and yes there is a resonance at 1500-2000 rpm so maybe she's right; it may be the exhaust. (i assume the tranny does not cause a vibration is in park). any which way the new rad is going in and the fluid is being flushed or changed.
Steve, i'll give you a call in am. i made conact with you that should not pose a prob.
Old Jan 21, 2007 | 08:23 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
get the NEW tranny it will fail
Old Feb 2, 2007 | 04:06 PM
AWDman's Avatar
Hey Steve. Here's the thread re IC pump replacement. Sorry I didn't print it out. See you tomorrow. (for radiator and IC replacment, tranny flush etc)
https://mbworld.org/forums/c32-amg-c55-amg-w203/146457-1fastc32-s-cheep-intercooler-pump-replacement.html
will post update on findings after Steve is done. I'm keeping my fingers crossed that the vibration is the new supersprint exhaust just bolted on.
Old Feb 2, 2007 | 04:33 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
So, you guys are saying the MB should/will change the defective radiator and fix any issues associated with it?
Old Feb 19, 2007 | 07:14 PM
AWDman's Avatar
THANK YOU STEVE!
mastertech tranmissions is a farily large shop. 5 lifts i think. Steve is the original owner of a black c32 amg plus has some very cool cars including a 928
Steve installed the baer radiator, flushed the tranny, installed the lighting IC pump, installed my clear fogs.
my fears regarding coolant contamination were basically unfounded. Steve commented the fluid looked in good shape so i didn't bother to have it analysed. the vibration i was feeling was coming from my new supersprint exhaust touching a bit on the car's frame. my c32 runs smooth i can't remember it being like this before. the wife noticed as well.
so, all's well that ends well. i'm basically ready for my track days. if i have trouble putting down the stage 2 power then I will return to Steve for a LSD as he is a quaife dealer.
Steve will also be installing a LSD and bigger crown wheel/pinion on my track car a suzuki swift GT.
Steve/Mastertech came through for me and have my 100% recommendation.
Old Feb 19, 2007 | 07:25 PM
rlee02135's Avatar
2004 C32 ///AMG
also had this problem...they replaced the transmission, radiator and torque converter under warranty
Old Feb 20, 2007 | 08:44 PM
C32AMG/02's Avatar
THANK YOU STEVE!
I love those fog lights. I am happy you’re satisfied with the job it did. Thank you.
My shop has 7 lifts.
Old Mar 6, 2007 | 01:29 PM
mendy9677's Avatar
I have a 2003 c240 4-matic, and I have the coolant in the tranmission problem. Unfortuantely, i am just out of warranty and did not know about this problem before hand. I now need a new tranny, torque-converter and radiator. MB will only agree to cover half the cost, which means I am still out between 4-5k. I have searched and it looks like the c32's have this problem the most. Is this a problem that other models have as well? Where can I find info on if there has ever been any TSB's issued on this? Any info will be helpful. Thanks.
Old Mar 6, 2007 | 06:35 PM
mleskovar's Avatar
'17 Jaguar XF
How far is "just"? Do you know if there was ever a service order that mentions transmission problems during the warranty of the car? Go to: https://mbworld.org/forums/c-class-w203/122140-w203-technical-service-bulletins.html
Old Apr 4, 2007 | 05:54 AM
KJI3jflarryfe93's Avatar
Post
Hey fellow mb owners i'd need to know if this problems also occur on the c-klasse 202,my car is a C43 AMG 1999, did mercedes use bad coolers from the brand VALEO on the c-klasse 202,I'm getting worried about reading scary topics like this cheers mates.
