Flashing ECU
2003 CL600
Flashing ECU
I have a question regarding what "Flashing" the ECU means. Does it mean to just clear the stored/error codes in the computer, or does it do something else? I'm not talking about any kind of aftermarket tune, just a stock ECU Flash.
An indi repair shop suggested I flash the ECU because the throttle actuator sensor seems to a little out of wack (on hard acceleration, when you let off, it keeps going for about a half second). Also, the transmission doesnt seem to engage properly. They said since everything is electronic on these cars
(2003 CL600), the transmission itself isnt the problem, just a reflash was needed.
Anyone have any input on this? If the "Flash" is just clearing the codes, can I buy a code reader and do it myself?
These cars are too complicated for shops that don't work on them exclusively. Do yourself a favor and take it to the dealer.
C63 AMG (stock right now), Beach Cruiser (debadged), Piper Cherokee 280 (too much to mention)
I bought a Carchip E/X by Davis Instruments
http://www.davisnet.com/drive/produc...p_products.asp
It enables you to clear check engine lights and find out your DTCs. As well as a few other cool features.
enjoy!
enjoy!
[QUOTE=Cops_h8_me!;1960089]I bought a Carchip E/X by Davis Instruments
At $179 what can it do above what a $40 OBDII scanner does? Not busting your chops, just curious.
03 E500 and Corvette
enjoy!
enjoy!
Is the Mercedes E500 03 model OB II compliant? Thanks Jim
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
All cars sold in the US starting in 1996 had to be OBDII compliant. There are many protocols that cars use, and in 2008, all cars will have to use the CAN protocol.
If you buy an OBDII reader/scanner, you may want to get one that's CAN compatible as MB has some CAN buses in them.
If you are really thinking about buying something to read DTC codes, I recommend you get one that runs on a laptop or palm so you can have graphs of various sensors (i.e., O2 sensor's voltage swings), in addition to seeing a lot of data all at once -- the small handhelds make you push buttons many times to scroll through all the codes (stored DTC's, pending DTC's and freeze frame data).
I've checked out 2 models, one from AutoTap and another from Auterra (called Dyno-Scan) and they're between $200-250. I tend to like the DynoScan layout, but if you like dials/gauges, then the AutoTap is good. They both have CAN compatible models. I haven't bought anything yet.
These scanners will read all the generic P0xxx (standardized) and most of the P1xxx (manuf codes).
http://www.autotap.com
http://www.auterraweb.com
Regards,
paul...
Also,......
Jim,
I forgot to mention that these scanners can record/playback, so you can hook one up and drive your car around and then see how the sensors operated after playing it back (don't drive and watch the computer!!)
The "P" codes are for the Powertrain and are all related to emissions.
The Auterra unit also has a dynometer as part of the unit, that's why it's called "DynoScan".
Regards,
paul...
Regards,
paul...
