ESP Disableing on W211
Old Mar 17, 2007 | 11:01 AM
AkMadness's Avatar
Mercedes E350, E550s on it's way!
Hello MBTech,
I admagine you recieve this question all the time, but I was wondering if on my E350 06' you know of the procedure to disable the ESP. Any insight on that would be very much appreciated.
Thank you,
Adam
Old Mar 17, 2007 | 12:01 PM
whoover's Avatar
'19 E63S sedan
Originally Posted by AkMadness
Hello MBTech,
Thank you,
Adam
You can only disable all the electronics (including ABS, BAS and ESP) at the same time, by putting the car in dyno test mode. This is not recommended for street driving, but we've all done it if you're in a safe situation and want to see what it's like.
Put the key in position one (first click to the right), make sure the odometer displays in the cluster and press the R button (odometer reset) three times in a row. You should get the engineering menu on the cluster. Use the steering wheel menu button to scroll to dyno mode enable. Use the + button to turn it on and then start the car.
Old Mar 17, 2007 | 03:47 PM
AkMadness's Avatar
Thank you very much!
Old Mar 17, 2007 | 03:59 PM
AkMadness's Avatar
Talking A little more help please!
When I put the key in, should it be on any certain menu or just have the cluster appear? Because when tapping the reset button three times nothing happens, but if I tap three times slowly and hold on the last tap it will say would you like to reset to factory settings, just changeing the lights and such in the vehicle. A little more detail would be greatly appreciated!
Thank you,
Adam
Old Mar 17, 2007 | 04:15 PM
whoover's Avatar
'19 E63S sedan
Thank you,
Adam
The cluster has to be on the odometer view. And the key has to be turned to position one, the "aux" position -- not position two that energizes the ignition.
Old Mar 18, 2007 | 01:51 AM
AkMadness's Avatar
Thank you very much Whoover! Was able to disable it and test it out, and I'm very pleased.
Thanks again,
Adam
Old May 17, 2014 | 12:03 PM
Ramachris's Avatar
W211 e240 '06 avantgarde
It didnt work on my w211 e240. Is there any different step to disengage the esp, abs, etc?
