Which brand filter for oil change
Old Apr 16, 2007 | 03:24 PM
Zoom On's Avatar
'02 CLK55
Ok so I got the 0w40 Mobil 1 ready to go, need to get the filter. What I have found is 000 180 2609 for a part number. I found two MFG Mahle and Hengst, any preference?
Also I like to make sure I get all the oil out, so I always use the drain plug. I have read where some have two. Does the 02 CLK55 have one or two drains?
Old Apr 16, 2007 | 05:26 PM
lkchris's Avatar
'10 CL550, '12 GL550
If you want to make sure you get all the oil out, vacuum it out the dipstick tube like dealer does.
Old Apr 16, 2007 | 07:59 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
The MB dealerships do this to save on labor time only not because it is the best way to do an oil change. You cannot suck all the dirt and metal filings out with a tube.
Old Apr 16, 2007 | 09:35 PM
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
Any examples of a vehicle FIRST being sucked dry, THEN the drain plug pulled AND the volume expelled measured? The reverse order is also required to document which works better.
So, a pump guy should run the two tests to settle the debate. 1) Pump it, then drain and measure. 2) Refill w/ drained oil. 3) Drain it, then pump and measure. Report on which LEAVES more oil.
Old Apr 16, 2007 | 11:55 PM
Zoom On's Avatar
'02 CLK55
I would venture to guess by logic that a hole in the bottom of your pan will get all the oil out vs. suction. You cannot see if your hose is at the bottom and if there is any residue left. I am sure the amount left is tiny but still left and the heaviest (sludge and or metal frag) is left on the bottom. I have not looked but every car and bike I have drained used a magnetic plug that I cleaned too. (does the MB have a magnetic plug?)
Old Apr 17, 2007 | 04:03 PM
benzeboy's Avatar
ml320 & c240
I used the drain plug and when it's completely drained with the drain plug off I pour about 1/3 of a quart down just to kinda get all the old oil out. I have used the Hengst filter it works fine for me.
Old Apr 20, 2007 | 08:05 PM
baybenzo's Avatar
2003 E320 sport
i heard they do it to prevent corrosion on some bushings or hoses due to the oil dripping onto them
Old Apr 21, 2007 | 02:31 AM
Ben'z's Avatar
E320
Well, so... which brand filter for oil change?
Old Apr 21, 2007 | 10:41 PM
Zoom On's Avatar
'02 CLK55
well I went with Mahle (made in Austria) but I may have gotten the wrong ones as they did not fit? I have an AMG and it would not slide over the fat part of the filter stick.
