OBDII Connection Failed
Mileage: 6k
I'm trying to get New Jersey inspection done but the car fails to connect with the OBDII. The inspection system says ODBII connection failed. I took it to the dealership and they printed out some papers saying everything is fine. But according to NJ law, all cars must respond to a "generic" ODBII request. They told me the dealer did a "manufacture" ODBII request. Can someone please help. Thanks.
The dealership is giving you the automotive equivalent of
Patient: "Doctor, my arm hurts when I move it like this."
Doctor: "Then don't move it like that. Next!"
The On Board Diagnostics system is composed of a computer that monitors the emissions system and key engine components. It can usually detect a malfunction or deterioration in these components before the driver becomes aware of the problem. The U.S. EPA has required auto makers to install OBD systems on all cars and light-duty trucks made since 1996.
OBD systems are designed to alert the driver when a component in the engine management or emissions systems begins to deteriorate or malfunction. Early detection of minor problems, followed by timely repair, can often prevent more costly damage to components such as the catalytic converter.
Are OBD related repairs covered by my warranty?
Federal law requires that the emissions control systems on 1996 and newer vehicles be warranted for two years or 24,000 miles (which ever comes first). Many auto manufacturers provide extended coverage as well. Federal law also requires that the on-board computer and the catalytic converter on 1996 and newer vehicles be covered for 8 years or 80,000 miles. Consult your vehicle owners manual or warranty for coverage.
This means that it must work and if not under warranty you might have to pay the dealer to repair the OBD II system to meet the law.
Just $.02 worth of info. Jim
So I talked to the dealer. The guy said that they found some old software and have updated it. But when they connected their OBD2 scanner, it wouldn't connect. They think the problem is within the software. So they called their independant engineer so he can help them with the problem. I have been without the car for a week now. I hope they fix this.
Regards,
paul...
You can also go to an Autozone store and have them plug in their scanner to see if it will connect.
Regards,
paul...
Sorry, but I don't know of any tools that can determine which protocol a car is using. Most of the newer OBD2 scanners (for 1996+ cars) can read multiple US protocols including CAN.
Regards,
paul...
