Rear break question with a twist
Old May 3, 2007 | 11:49 PM
Zoom On's Avatar
'02 CLK55
Ok I went to put my new lowenhart rims on and got the lugs that were suppose to fit and problem. I started to back up and I could hear a weird rubbing sound. I had checked clearance when I put them on and I was well fine. So I jacked up the car put it in N and spun the tires and sure enough something was rubbing or dragging. I put the stock back on and fine so I looked in the hole and could see springs and parts inside the disk hub. Is there a mini drum break for the parking break? The bolts would hit the springs inside and kind of bind up.
Old May 4, 2007 | 08:42 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Originally Posted by Zoom On
.......... Is there a mini drum break for the parking break? .........
Yes, the rear rotor hat is machined inside and serves as a drum/shoes style brake for the parking brake.
Regards,
paul...
Old May 4, 2007 | 09:39 AM
lkchris's Avatar
'10 CL550, '12 GL550
Aftermarket parts suck, don't they?
Old May 4, 2007 | 10:26 AM
Zoom On's Avatar
'02 CLK55
Thanks, looks like I need to get a touch shorter bolts.
Not really, just getting the kinks out sometimes does though.
Old May 5, 2007 | 02:12 AM
tcesario's Avatar
09 E350 ,
first thing is to fix the e brake springs ,then get lugs that are shorter ,it could cause bigger problems down the road
Old May 5, 2007 | 04:03 PM
Zoom On's Avatar
'02 CLK55
Shorter ones are on the way, and e brake was ok.
