Where to Get Oil Change?
From what I understand, there are standard mileage rates to where I'm supposed to have the car serviced. But what about oil changes? Does the 3 month/3,000 mile rule apply to my car for oil?
I appreciate everyone's input... and again, forgive the "newbie" question. I'm learning...
There are very few oils that are acceptable in that car. It also needs a special fleece oil filter. I would never trust a quick-change place to use the right stuff. You've just saved on three out of the four oil changes. Spend some of that by only letting the dealer change the oil. Service your car by the book at the dealer and (if your dealer is competent) it will run longer and may even be cheaper in the long run.
Your question is fairly broad, so you will - no doubt - get a wide variation of answers.
For me, I change my own oil every 4,000 and when I lived in California I changed my own oil. The City of San Jose had an excellent oil recycling program. But here in Texas, it's not that easy. So I take my MB's to a local independent (sometimes called "Indies") oil change facility. You know, Jiffy-Lube, etc.
HOWEVER - and this is a huge *however* - it is crucial that you find one that is reputable, technically competent and uses the oils that YOU want to use - not what they want to sell you. This is not always an easy task! You may have to search a bit in your local area. If you are unsure, then by all means continue to utilize the MB Service Centers. But the Indies will be cheaper for you then the dealer. Just make sure you get the oils and consumables (filters, etc.) that are spelled out in your owner's manual.
Your owner's manual, or elsewhere on this board, will tell you what brands/weight of oil to use, as well as how often to change the fluids. Finally, a review of your service records done to date should tell you how often to service.
Oil change places can also do *some* other fluid maintenance, such as manual transmission oil changes, gear lube change, etc. For automatic transmission oil changes, I have an independent repair shop that is Mercedes-knowledgeable do mine since the oil change places rarely change the transmission filter or drain the torque converter.
Before buying this MB I had a BMW and before that a VW... I've been slowly making my way up the German car market
I'm very pleased with my E-500 so far. I know that upkeep can be expensive, but the cars are good and will last forever if taken care of.I'm going to stick with the dealership for the first servicing. Though, the car says I've got another 10K or so miles before it needs anything... I think it says "G" service is due then?
Anyhow, I really enjoy this board and its already helped me tremendously.
Thanks for all the help! (and for the welcome).
I've attached the W211 service sheet so you have an idea of what services are required and when.
Good luck with the car and welcome to the MBWorld forum -- we're all here to help eachother!!
Regards,
paul...
