Need Suggestions.... BAS ESP ETS Light on
Fiancé said the both the ESP/Bas light, and ETS light were lite in the ML. Also, her cruise control was not working at all. The ML has no power loss, can easy go into gear, and seems "normal" other than the lights.
I did the steering wheel lock to lock test... lights stayed on....
I think it is the brake sensor behind the pedal.... does that sound right?
Here is the link: BRAKE SWITCH
The light will need to be cleared regardless.
On the link people were changing the switch and having the lights go off.... at least it seemed that way.
Burt contacts on the relay for the ABS pump.... Where is that located?
Thanks!
I replaced the new switch in about 5 minutes and turned the car on......BAM NO CODES!!!!
Took her for a test drive and the cruise now works.
Those brake switches are super crappy parts!
