lifter tick on my friends E class
Old Nov 19, 2007 | 09:42 PM
Mikegpr03's Avatar
C63
Hi guys My friends E class has a lifter tick & he doesn't know what to do with the car. I told him to change his oil and try a flush kit...no luck any suggestions.
Old Nov 20, 2007 | 01:30 AM
tirona's Avatar
1997 s320, 1997 e320
what year/model? what kind of oil is he using? is he sure it's the oil lifters ticking? tell him to add a can of bg44k to a half full gas tank, it will clean the fuel lines really good. i think advance auto parts sells bg44k for like $15-20. it;s a little expensive but works better than techron or the gas treatment that mb sells.
if that doesn't help than suck 1L oil out and add 1L of non-synthetic atf, i was suggested this procedure in order to quite lifters.
Old Nov 20, 2007 | 08:52 AM
Untertürkheim's Avatar
Is he using synthetic oil? If not, it is probably varnish buildup. Can you provide more information, year, model, oil used, etc?
Old Nov 20, 2007 | 08:57 AM
vettdvr's Avatar
03 E500 and Corvette
Lifter tick is common, I can hear some in our E500 from the day we drove it out of the show room. But I agree, you must use MB spec oils in the engine to prevent issues. If it is running MB approved lubes I would just drive it out unless it is really hammering then back to the dealer to check for defective lifter/camshaft issues.
I don't use snake oils..
Old Nov 20, 2007 | 11:37 AM
Mikegpr03's Avatar
C63
E500 and he uses mobile 1 its an 05
Old Nov 20, 2007 | 01:04 PM
lkchris's Avatar
'10 CL550, '12 GL550
If it's and '05 it will still be under warranty unless he's past 50K miles. He should just take it to dealer.
