ML430 oil question what weight?
Old Dec 10, 2007 | 12:25 PM
RAFFIE55's Avatar
Used to drive E55
Just wondering if anybody has used Mobil one 15w50. I have a 1999 ML430 with 120,000 miles. I just did and oil change and I used 15w50 instead of the usual 0w40. I know MB specs are 0w40. But since it's a high mileage and I live in California, should this weight be O.K. or should i switch back after 5000 miles. I hear a lot of debates on weights.
Old Dec 10, 2007 | 02:56 PM
Diesel Benz's Avatar
I would not use 15W even in California. But it isn't only the viscosity, it should have minimum MB229.3 approval, preferably 229.5 and I did not find Mobile 15W- 50 fulfilling this:
http://www.whnet.com/4x4/oil.html
Old Dec 10, 2007 | 03:06 PM
RAFFIE55's Avatar
Used to drive E55
I hear you. But it is on the
MB sheet 229.1 approved oils
for passenger cars with gas and diesel engines, used to be minimum spec for latest (98+) engines
Old Dec 11, 2007 | 10:20 AM
vettdvr's Avatar
03 E500 and Corvette
I would drive it the normal time then change to the 0w40. The oil used is also a good oil.
Old Dec 13, 2007 | 12:45 AM
211076-113990's Avatar
1965 continental
stick with the 0w40 mobil, 15w is too heavy at startup. I would also recommend sticking with the flex intervals. 5k is too early for a change, your just wasting money. My 98 E320 has 270,000 miles on her and has always had the flex services only.
