Tech help needed. Heater issues
1. Cover for sunroof continues to make a tapping/clicking sound when going over bumps. Been in twice for foam inside the headliner but doesn't solve the problem. The noise is coming from the rear area of the shade.
2. Heater: For no apparent reason, I sometimes get cold air blowing on my feet on the driver's side, even when there's a call for heat, and heat is blowing from the other vents. When it blows cold, the only way to get heat down there is to turn the temp dail up to max (but it gets too hot). This is an intermittant problem and the dealer can't duplicate it.
Thanks in advance, and any/all help is appreciated.
The good news is...the sun roof cover/shade was fixed (for the third time).
It really sucks that I bought this vehicle as a present for my wife. She's not getting any enjoyment out of it.
You might take it out of auto mode put it in manual and see if there is any difference.
Bro, I'm thinking that you're an eff-ing genius. However...regarding "off by 8 degrees," was yours set 8 degrees higher or lower than it should have been? Brilliant, Dude, just brilliant.
I'm keeping my fingers crossed.
Did you have the same symptoms that I do?
