solve the battery paradox
1 Post
2003 S500, 03 C240, 03 E320, 03 tahoe
it's a question that should answer itself.car cranks slow or wont start,replace the battery.but what if we dont want to wait for a sign that the battery is losing it's ability to store ampers/current.forcing all the electrical components to endure low volts/current and working the alternator like a sherpa climbing everest.i know the dealer checks during scheduled service, but would it be foolish to simply replace the battery every 3 or 4 years and avoid ever having a battery go bad from age?
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
You may have a VHLA (dry cell) battery fitted to your vehilce so the usual time frame for battery replacement is greatly changed.
I've seen plenty of W202's and W210's last 10yrs on an original battery.
The genuine GERMAN batteries are pretty good if maintained. South African and American batteries never last anywhere near as long in my experience.
I wouldn't worry about it, just wait for the early warning signs (slow to crank)
i have a hydrometer and a voltmeter. both are easy tools used to determine
the health of a battery. i usually check the specific gravity every couple of
months and replenish with distilled water, then trickle charge. 5 yrs is a
minimum life span for my m/cycle batteries. longer for automotive. my poh
buh-hind unable to buy new batteries every several years for truck, car,
4 motorcycles.
4 motorcycles.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
I have always been proactive and replaced my batteries in all my power equipment, vehicles, etc after 4 years. I have never been stuck with a dead battery since starting to do this. The cost is negligable.The benefits are very good.
1 Post
thanks for the input,
the battery in our 03 is the german vhla.ive picked up some valuable input from the threads.first.if you have the german battery keep it as long as possible.second,if you are going to replace it go with another german battery which is gonna cost big $.ill probably simply replace since i bought the car with 43k miles and dont know the history of use/abuse.ill get another vhla with the intent to make it go at least 5 years.im probably just being paranoid but on our last road trip i noticed the cluster flickering/dimming slightly,it coincides with accessories cycling on/off.ie'a/c compressor,applying brakes flashing the brights.im thinking weak battery.
03 E500 and Corvette
My son told me to replace the battery in my F150 in 2001 because it was 4 years old and cranking slow. He now has the truck and I told him not to change the battery in 2008 because it is still cranking slow, but it does crank. So the battery was bought in 97 and that makes it about 11 years old,, but still cranking. So what would be the right time to change this Duralast battery? I don't think there is much warranty left.
1 Post
It changes all the time
My son told me to replace the battery in my F150 in 2001 because it was 4 years old and cranking slow. He now has the truck and I told him not to change the battery in 2008 because it is still cranking slow, but it does crank. So the battery was bought in 97 and that makes it about 11 years old,, but still cranking. So what would be the right time to change this Duralast battery? I don't think there is much warranty left. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
whatever u do .....just dont take the battery out and close the trunk...ull never be able to get in there ....that is if u have a clk cabrio ....just my luck!!! now im stuck with a 02 clk 430 cabrio in my drive way and i cant drive it...lol im sure i get in the trunk again.....how i dunno....now remeber theres no battery in there so if postive is touching the chassis and if i try to jumpstart it from under the hood.....there goes the ecu !!! so theres a big tip !!!! dammit!
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1 Post
i know it sounds crazy,but
whatever u do .....just dont take the battery out and close the trunk...ull never be able to get in there ....that is if u have a clk cabrio ....just my luck!!! now im stuck with a 02 clk 430 cabrio in my drive way and i cant drive it...lol im sure i get in the trunk again.....how i dunno....now remeber theres no battery in there so if postive is touching the chassis and if i try to jumpstart it from under the hood.....there goes the ecu !!! so theres a big tip !!!! dammit!![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
