screeching/highpitch Siren/alarm problem
2004 CLK500
Ok guys I need help.
I have a W209, and I started to notice the chirping noise when you arm/unarm the car doesn't sound anymore. Didn't think anything of it. It's been like that for the past few weeks.
Anyways, the past few days if I get out of the car, get stuff out of the trunk etc.. there's this really high pitched screeching/irritating noise that sounds like its coming from the front left area. I'm assuming its the siren for the alarm that may be starting to die. The only way to stop it is to start the car, let it run for a bit, and pray that it doesn't happen again.
The best similar noise comparing I can say it sounds like is a fax machine. The part it sounds like is the 'beeeeeep <________>". Basically that garbled noise after the beep. The screeching noise is not constant, and sometimes the screeching sound flutters of that makes any sense. BUT, when it is constant, it does sound like the alarm going off.
Before I bring it to the stealership I wanted to know if there's anything I can do to see if its possibly a loose wire, or something easy I can do myself. This problem is very random so I know when I bring it into the stealership it won't happen. Would this be also be related to why the chirping noise doesn't work when arming/unarming the car anymore?
W209 CLK
You had chriping noises when you arm/disarm the car? Is it a stock alarm? I thought the only way to get it to chirp was to have it under the Netherlands setting...
2004 CLK500
It's using the stock alarm, but the beeping noise from the netherland settings disappeared and the random fax machine noise coming from the siren I believe is the siren for the alarm.
I've heard from someone on benzworld.org that the siren in my car is probably dying, I was just wondering if the netherland beep and alarm noise comes from the same siren or not...
03 CLK 500/AMG Sport Package & 03 Mazdaspeed Protege
Mine makes no sound either, how do i activate the Netherlands setting, btw i just got the car on Saturday so i'm still trying to figure everything out.
My car did the same thing. The alarm system module was messed up. It didn't cost too much - I think $70 for the parts + labor. It was corroded or something from road salt.
It sounded like the alarm system suddenly became retarded or something. It was irregular and messed up.
But it was on the front right, not left, under the car.
1 Post
08 CLS550 Diamond White 09upgrades
Exactly
Exactly... but here in California the dlr charged me over 100 for it... that was a little over a year ago.
NOW! just this week, it's BACK!!! so my alarm chirps / goes off at random again!!! so
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
SO => there might be a possible cause from Netherland mode. and maybe not ALL cars with netherland mode, but some; yours and mine!!!
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
I'm so frustrated with it.... I almost want to rip out the siren horn... but knowing Benz, there WILL be error codes that's going to annoy me some more.
1 Post
07' E350, 71' DATSUN 510
Sounds like the internal battery for the alarm siren might be on its way out. When the siren sees the voltage getting low it sounds off, thinking that someone is disconnecting the battery in an attempt to steal the car.
Replacing the siren itself might remedie the issue. Usually there would be a
dtc set for a faulty alarm siren.
2004 CLK500
I haven't had a faulty alarm siren warning or anything yet..
1 Post
No, no display warnings, but a dtc set in the rear SAM I believe.
And, I'm not positive, but it's possible that a low internal battery could cause the "netherlands beep" not to sound.
2004 CLK500
Update:
Car is fixed. My benz mechanic replaced the siren and everything is ok now. Alarm siren and netherlands beep both work again..
woot!
woot!
2004 CLK500
I had my mechanic replace the siren. Everything is back to normal now and the netherlands beep is back. So if it's the same situation as mine... just replace the siren
2004 CLK500
It wasn't working before but I haven't really tried it after the siren got replaced either... But... I read somewhere on here or it could have been benzworld that if you have your car in netherlands mode, your panic button is disabled..
I can't remember exactly where I read that but since then I never really looked into it.
