Key wont turn in the ignition
1998 clk 320
If you don't have a voltmeter, Radioshack has them very cheap that will work for this test. The fact that it does it in the morning really sounds like a weak battery. If the key switch were defective it would be random and occur at any time. The battery will always be weaker in the morning.
http://www.babcox.com/editorial/ic/ic030538.htm
Sometimes taking the car to the dealer is the cheapest way. If you have an electrical drain and not a bad battery, you just wasted some money already.
I would still do voltage checks and have real data to know what is happening. The seat module could be a problem but without knowing voltage we can't tell. But since you are taking it to the dealer,, let us know what they found.
