92 190e 2.6 EATS OIL, 1 qt. every 4-500 miles! help
Old Aug 26, 2008 | 10:41 AM
spinlps's Avatar
16 E350 wagon, 94 AMG, sold -95 E320 Sportline wagon & 94 E420 & 95 E320 coupe & 92 190 16v
Hi
My Wife drives a 92 190e 2.6 Sportline that eats oil like crazy. Our tech can't find any leaks or reasons why it happens. The engine is clean and we have never had even one drop on our driveway.
MBUSA specs the car will eat 1 quart every 750 miles but ours is down to about 1 quart every 4-500 miles. The car drives great and passed smog with flying colors. The only odd thing is it seems to idle low and somewhat rough for the first 5 seconds or so after starting and then comes up to spec and is fine.
Adding oil all the time is getting old and expensive. Please help! Many thanks...
Old Aug 26, 2008 | 02:22 PM
lkchris's Avatar
'10 CL550, '12 GL550
You either didn't pay your "tech" enough to find the problem or else he's just not good enough.
It's the same as any engine--leaks past rings, past valve seals. You don't find these things by looking, you find them by testing compression.
Old Aug 26, 2008 | 02:53 PM
spinlps's Avatar
I hope that is not the case on my tech as been the best guy in town with regards to our two other MBs.
The compression was over 185 on all 6 cylinders. Any ideas?
thanks
Old Aug 26, 2008 | 03:18 PM
Untertürkheim's Avatar
thanks
Has he checked the valve seats? Where and how is it burning? Evenly in all cylinders, or only in some?
Are your spark plugs ever wet from oil?
What type of oil are you using?
Old Aug 26, 2008 | 05:02 PM
lkchris's Avatar
OK, sorry about badmouthing your tech.
Nevertheless there's simply no such thing as "can't find why it's burning so much oil."
There may be "can't find it without charging you more than you want to pay to find it" of course.
Old Aug 26, 2008 | 07:19 PM
Very true, one of two things must be lacking in order for this situation to occur; competence on the part of your mechanic, or money on your part.
Old Aug 27, 2008 | 03:01 PM
spinlps's Avatar
I guess I'll have to ask him. I've spent quite a bit of money with him so I don't think that is it but I would actually rather that be the case than his lack of competence in getting it solved.
thanks
Old Aug 30, 2008 | 04:34 AM
thanks
Any news? Has he checked the valve seals? Did he tell you how it was burning (evenly in all cyl, or otherwise; constant or intermittent)?
I had one hell of an issue with my 560 burning oil, it turned out to be a couple of things, mostly due to the oiler rails being slightly tweaked and not sealing at the ends, spraying oil all over the place under the valve covers.
Old Sep 1, 2008 | 11:20 AM
spinlps's Avatar
Not yet as my tech is true to his Euro heritage and took August off. He is back open 9-2 so I'll try to figure this out this week and let you know.
The oil disappearing at a constant, even rate.
Old Sep 1, 2008 | 01:09 PM
charliev68's Avatar
2000 CLK430
check your tailpipe and bumper. if there is black residue then it is your piston oil rings.
ask your tech to do a leakdown test...it will tell you exactly where your oil is going.
usually i pull the plugs and shine a flashlight into the chamber to see if it is wet.
Old Sep 6, 2008 | 10:27 PM
spinlps's Avatar
Yes, there is black residue on the end of the tail pipes...
I'm going to try and get the car into the shop this week and ask for the leakdown test.
thanks
Old Sep 8, 2008 | 04:12 PM
benz-tech's Avatar
BMW E30. I've turned to the dark side.
um.... nope. 103 engines are notorious for burning oil through the valve stem seals. premature valve guide wear is caused by less-than-ideal rocker arm geometry bla bla bla. worn guides allow the valves to shift sideways a bit and violla, oil gets past the hardening rubber seal. it is possible that a leakdown test will show poor valve seating but its the guides and seals that are usually the issue. Never have i seen a lower end have to come apart on these engines so it is highly unlikely that your piston rings would be the cause, as suggested above.
Old Sep 8, 2008 | 09:45 PM
charliev68's Avatar
2000 CLK430
with the amount of oil burning and the residue, are you sure that it is the valve train?
would not bad oil or too much oil fry the rings causing blow by?
with that said i "think" that a leakdown test will tell all.
Old Sep 11, 2008 | 07:20 AM
I can assure you that it is possible for that amount of oil to get in through the valvetrain, it happened on my car. I do not know if the M103 has an oil rail, but if it does, check it. That was part of the problem on my car.
The valve guide/seal issue is very common in the US because people here tend to use substandard/mineral oils in their engines, while the European market embraced synthetics much sooner and on a wider scale. The synthetics preserve the seals better, and also do not allow varnish buildup.
Old Sep 14, 2008 | 08:31 AM
MBTECH2003's Avatar
2000 ML 320, 2003 CBR600F4i, 99 Eclipse GSX
Valve job time. Common problem.... especially if it has never had one.
Old Oct 3, 2008 | 11:55 PM
spinlps's Avatar
Well, finally took the car to a different shop yesterday and the owner walked outside, looked at the tailpipe, wiped what I thought was dirt off the bumper, it was oil, and said it needs new valve stem seals as MBTech had stated above.
At just $275 installed I'd have to agree it was lack of competence on the part of my former mechanic.....
Thanks to everyone for the help!
Old Oct 4, 2008 | 08:34 AM
MB4LIFE13's Avatar
S 320 white
before the valve stem seals go on ask him to measure the valve stem play, since the guides are a known issue for the 103 enigne family, if he is not an MB tech! i wish you luck, the money you are investing will soon be lost as the new valve stem seals will wear out soon.
