03 clk500 brakes
Old Nov 12, 2008 | 12:19 AM
Arya's Avatar
2003 CLK500
03 clk500 brakes
so my brakes are squeaking but the low brake sensor has not come on yet. how sensitive/accurate is this sensor? should i go ahead and change the pads or just clean them?
Old Nov 13, 2008 | 09:14 PM
epmills's Avatar
99 CLK430
Take a look at the pads first, you dont have to take the wheel off if you can get the right angle of view on it. If there is an 1/8 of an inch or so left, you may as well replace them, if there is more, you can try pull the pads out and apply brake paste to the back of the pads. They also sell a spray on anti-squeal stuff at most auto stores that works. Get the type for spraying on the rotors, not the pads, they sell both. But in my experience, the rotor stuff works better than a pad treatment.
Old Nov 14, 2008 | 02:49 AM
buffyclk500's Avatar
clk500
how hard is it 2 change the brake pads
Old Nov 14, 2008 | 12:43 PM
lkchris's Avatar
'10 CL550, '12 GL550
Squeaking has no relationship to brake pad material being worn off.
Yes, some 'merikun cars use a noise maker instead of a light to indicate worn pads but your car doesn't.
However from an economics point of view it's as easy to just install new pads as it is to fix the squeaking from the old ones.
Old Nov 14, 2008 | 01:31 PM
M-bENZ's Avatar
Corrolla
I would say go head and change it if u around 50K miles....I jsut ordered mine and will install this weekend.. here is the good info. about the brake parts
https://mbworld.org/forums/w211-amg/267913-changing-out-brake-questions.html
