I KNOW NOTHING
Old Dec 22, 2008 | 08:00 PM
RALPH221's Avatar
1981 380 sl
I KNOW NOTHING
I RECENTLY PURCHASED A 380 SL 1981 FROM A FRIEND WHO HAS PASSED ON. I WANT TO CHANGE THE OIL BUT I CANT FIND THE OIL PLUG. ANY HELP WILL BE APPRECIATED.
Old Dec 22, 2008 | 11:28 PM
charliev68's Avatar
2000 CLK430
my friend, you'll save more time and money by going to your local walmart and getting it done.
it's an 81, there's nothing special about it. any local lube shop will do it for you for cheap. you can even find coupons.
Old Dec 23, 2008 | 04:04 AM
Untertürkheim's Avatar
DO not do this. The job is simple, but there are many ways in which it can be done improperly and cause a lot of damage. Those idiots have no idea how much torque goes on anything and which washers need to be replaced, etc.
Also, use good oil, Valvoline syn or M1 are very good. 0w-40, 5w-40, are the proper weights.
Has the timing chain been done, if not, it should be ASAP.
Old Dec 23, 2008 | 11:03 AM
lkchris's Avatar
'10 CL550, '12 GL550
Your car is designed to have the engine oil removed via the dipstick tube.
You'll need a tool for this.
Old Dec 23, 2008 | 11:11 AM
CLK Operator's Avatar
Currently Benzless
Exactly, do not go to Walmart of Jiffy lube for your oil change. It is only asking for trouble. If you don't want to do it yourself find a independant Mercedes shop and have them do it.
Old Dec 23, 2008 | 05:53 PM
Gullwing's Avatar
1987 190E 2.3
After filling the engine with oil, crank it over for several seconds before starting it up. If you start it without building up oil pressure the timing chain can slap/come off/slip a tooth. $$
