03 E500 coil wire plug
Old Mar 27, 2009 | 12:04 PM
vettdvr's Avatar
03 E500 and Corvette
OK,, I put in new plugs and one of the plugs to the coil pack broke the locking tab. It still fits tight and is inserted in the coil. The wireharness is good no cracks etc. What I would like to do is install a new plug on the harness that fits into the coil. This appears to be the same part as on the V6.
Napa doesn't stock the plug and I haven't found a MB part number. MY fear is that MB sells only the entire harness and what I need is the plug.
The plug is the #2 if I have the order right. Pass side most forward plug. This is the coil pack with the tie wrap holding the wire harness to the coil so the wires don't chafe. I put the tie wrap back on and basically this is keeping the coil plugged in.
Anyone have these part #'s or know where to find it.. Thanks
Old Mar 27, 2009 | 05:24 PM
lkchris's Avatar
'10 CL550, '12 GL550
Mercedes is very good at providing availablilty of electrical connector repair parts. Have parts man look up "54 Engine Cable Harnesses." Think attached shows what you need.
Old Mar 27, 2009 | 05:58 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
They are avaliable throught benz... they break all the time when plugs are done.
If you are talking about pass side 1st plug/cylinder that is number 1 cylinder
If you need the number still i could get it monday..
Old Mar 28, 2009 | 10:07 AM
vettdvr's Avatar
Thanks for all the info. Looks like
2035453028 is the wiring harness plug for the coil. So far I haven't located this at any online supplier guess it is a 100 mile drive to the dealer.
Old Mar 29, 2009 | 09:35 PM
MA Mechanic's Avatar
1987 420SEL
http://www.adsitco.com/
they have everything for MB and its OEM, i get all my parts there
Old Mar 31, 2009 | 10:46 PM
hcetzneb's Avatar
If its that small have the dealer ship it ..... 100miles for that wow that would suck
Good luck man
