1987 420SEL Starter screeching not engaging to engine sometimes
any help would be great thanks,
Nick
If you haven't damaged the flywheel it is probably the starter drive not engaging full. You might be able to rebuild the starter but consider a new one. I had a 77 olds at 100000 miles do this and roll over 1/3 of the flywheel teeth
. So I figured I needed to pull the transmission and put on a new wheel. I bought the flywheel but had not installed. I decided to use a dremel on the teeth to polish/shape the burrs off the rolled teeth. Wow after doing that it never missed engagement. The starter always engaged. A friend of mine bought the car and drove it another 125,000 miles on the same starter and it never ground again. Finally the engine died.So you might be able to massage the teeth on the flywheel. But I would immediately pull the starter and replace with flywheel inspection.
