Need advice on oil filter brands
2007 CLS 550 (Black)
Hello. I recently purchased a 2007 CLS 550. I plan to do a DIY Oil Change.
I found a few different oil filter brands. Anyway, what oil filter brand do you use? Is there a major difference between the fleece and paper type filter?
Here are a few of them:
2007-2008 Mercedes Benz CLS550 - Hastings Oil Filter
2007-2008 Mercedes Benz CLS550 - Beck Arnley Oil Filter
Mann (Oil Filter Kit; Upgraded Fleece Media; Extended Service)
Thank you for any info you provide.
1987 SDL; 2001 Chevy 2500HD CC, 8.1L, Allison special order; 1970 GTO LS2, 4L60E, under construction
Amsoil recommends the Mann HU7185X. They don't have an EA microfiber filter for that model yet.
Therere no filters on the market currently constructed of lamb's wool.
Interesting thought process. Truly special.......
"MB sheet 229.5 approved oils; "MB Longlife Service Oils"
for passenger cars with gas and diesel engines with extended drain intervals beyond 229.3 oils, to 30,000 km, min 1.8% fuel saving, first oils introduced summer 2002. ACEA A3 B4. For gas engines of the M100 series, gas engines of the M200 series and diesel engines of the OM600 series (not models with Euro 4 diesel particle filters).
229.5 engine oils must be used with fleece oil filter designed for use with 229.5 engine oils. "
And no, Amsoil is not on that approved list either.......
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
It is imperative that you use the required fleece oil filter that is specified by MB. It's in the owner's manual, specified by a sticker on the cap of the filter canister housing. You will not win any warranty claims once a non OE, non fleece filter is found to be installed.
Your only assurances of the correct filter are:
- Dealer OE
- Mann (usually internet only, Mann doesn't do much in the aftermarket)
- Bosch 72204 (OE or Mann in the box, complete with O-Rings)
I recently found a Fram replacement available at a local WalMart for MB. Scary. Compare the Chinese knock-off in the Fram box with the OE type, and it's no doubt why any warranty would be voided.
- Dealer OE
Straight from Webster's to the masses:
Main Entry: 1fleece
Pronunciation: \ˈflēs\
Function: noun
Etymology: Middle English flees, from Old English flēos; akin to Middle High German vlius fleece and perhaps to Latin pluma feather, down
Date: before 12th century
1 a: the coat of wool covering a wool-bearing animal (as a sheep) b: the wool obtained from a sheep at one shearing
Again, I state, there are no filters out there currently made of lamb's wool.
I'd stick with the Amsoil recommended filter. They're the only ones in this whole deal that display any knowledge in filters.
Main Entry: 1fleece
Function: noun
Reading is fundamental...
Main Entry: 1fleece
Function: noun
Main Entry: 1fleece
Function: noun
Perhaps my degree in Textiles (Manufacturing and Management of Textiles and Fibers, UMass Dartmouth, 1997) told me the answer before I copied it for you. Doesn't change the fact there are no wool oil filters. Fleece is being used as a generic term for filter media, which in this case, is pretty much an insult to anyone who understands technology or textiles/fibers.
That anyone, including MB, refers to filter media as "fleece" still tells me all I need to know about who's making the financial decisions within the company still.
No one but you indicated they were made from wool.
Your degree ought to have educated you in the usage of the terms used in your industry within the real world. Its no different than a serpentine belt "damper" that is commonly referred to as a "dampener" (a moisturizing agent in reality) by many individuals. Google will pull up a couple 100K hits on dampener "shocks" or 'springs".
My elementary school education (Bullock Creek Elem, Mi., 1970) taught me to consider others limitations.
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
![Gfight](https://mbworld.org/forums/images/smilies/gfight.gif)
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
03 E500 and Corvette
Main Entry: 1fleece
Function: noun
Main Entry: 1fleece
Function: noun
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
I guess Amsoil makes better filters that exceed the MB warranty by not killing sheep. Perhaps PETA stopped in at MB and told them no more sheep killing to save engines use Amsoil?
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Didn't mean to break-up the Goat vs. Lamb vs. Sheep vs Fleece discussion and put the post back on topic, let the argument continue.
2012 C300 4Matic
Are you retarded?
To the Original Poster, like everyone else said, you must use a filter made of what the industry calls "fleece" rather than paper material. It filters the oil much more finely, and will not break up into your engine over Mercedes long oil change interval the way a paper filter will. If you use the filter Goatman mentions you will void your warranty should any issue arise. Mercedes specifically REQUIRES the use of a fleece filter. There should be a sticker on the oil filter housing which says that.
Back to the textile argument, please read below you foolish idiot:
Fleece \Fleece\, n. [OE. flees, AS. fle['o]s; akin to D. flies, vlies .]
2. Any soft woolly covering resembling a fleece.
This may come as a shock to you, but words can have more than one definition.
Fleece can mean many different things. I think maybe it's time that you get some re-education.
Definitions of "fleece":
http://www.google.com/search?hl=en&s...ition&ct=title
Plenty of other industries that use differing fleece filters:
http://www.google.com/search?hl=en&s...er&btnG=Search
Need I go on?
Need I go on?
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
Are you retarded?
Need I go on?
Need I go on?
Fleece is made of lamb's wool. Are you retarded? Need I go on?
2012 C300 4Matic
Nice try, but my argument actually provided facts and made sense. Yours is simply pure stupidity (which I do admit is expected).
Lambs wool is one DEFINITION of the word fleece.
Take an English class - oh and by english, I mean the LANGUAGE, not the muffin.
See how that works? The word has multiple meanings! SHOCKING! More news at 11!
The same way synthetic oil is still called oil, a fleece like filter material can be called a fleece filter.
Even so you tried to have this guy install the wrong (non-fleece) filter, that could have caused him a lot of trouble. Either way, everyone knows the truth now. Go ahead and post what you will, the facts are now clear.
I'd recommened the Amsoil EA microfiber filters. As stated earlier, too bad they don't make one for this application. I guess the sheep still aren't safe in some parts of the country.
When it comes to sheep, I'll give you the expert label, that's for sure.
