Complete DIY's on starting, charging, engines, trannys, etc.
Old Aug 2, 2009 | 09:12 PM
Nitroholickid's Avatar
Lancer
Thumbs up Complete DIY's on starting, charging, engines, trannys, etc.
How's it going guys. Here are some completed DIYs that you guys might find helpful. The repair info isn't model specific but does give you a general idea of how certain parts work. Let me know if you guys see any errors.
- Anti Lock Brake Safety Information (ABS)
- Air Conditioning Troubleshooting - No cool air, noisy AC, etc
- Ball join check
- Brake System Troubleshoot - screeching noise, dragging brakes, etc
- Break-in procedure for new engines
- Camshafts - removal, cleaning, inspection and installation
- Charging System - No start, Noisy alternator, fuses burn out quickly, battery not charged
- Clutch Troubleshoot - chattering, rattling, slipping, stiff pedal, and more
- Cooling System - overheating, low coolant, refilling, flushing, and more
- Crankshaft and Main Bearings - removal, cleaning and inspection, installation and more
- Cylinder Head Overhaul - removal, cleaning, inspection and installation
- Drive Axle - Clunk Noises, Gear noises, vibration, and more
- FF Axle Shafts and CV Joint Troubleshooting
- RWD Drive Axle Troubleshoot - clunking noises, vibration and more
- Troubleshoot hard starting, rough idle, slow acceleration, Misfire, poor gas mileage, etc.
- Electrostatic Discharge (ESD)
- Emissions Inspection - PCV, TAC, Evap, Catalytic Converter, EGR and more
- Engine Services - bead blasting, cold tank, steam cleaning,
- Engine Damage Inspection - Magnaflux, Zyglo, Dye Check, Ultrasonic, X-ray
- Engine Overhaul - cleaning, cylinder head, pistons, rods, crankshaft and more
- Engine Troubleshoot - rough idle, hesitation, backfire, detonation, low oil pressure and more
- Fuel System Troubleshooting - Hard starting or no-start, ping on acceleration and more
- Heater System Troubleshoot - Low or no heat, blower not working and more
- Troubleshoot ignition system, no-start, engine runs rough, etc.
- Proper vehicle jacking and wheel removal procedures
- Manual Transmission Repair - Troubleshooting noisy gears, gears clashing, hard shifting, etc
- OIL PUMP - Rotor and Gear type
- Parasitic Load Explanation and Test Procedures
- Pistons, Connecting Rods and Bearings - removal, cleaning, inspection
- Power Steering Troubleshooting
- Safety in the Garage
- Spark Plugs - troubleshooting, carbon deposits, electrodes, etc.
- Starter Troubleshooting - no start, no clicks from solenoid, etc.
- MANUAL STEERING GEAR TROUBLESHOOTING
- Suspension alignment troubleshoot - tire wear, odd suspension noises, etc.
- Tie rod test
- Timing Chain and Belts - tension adjustment, gear backlash, runout, etc.
- Undercarriage Quick test - this finds loose suspension parts that need replacement.
- Warped Rotors - this test helps determine if your rotors are warped.
- Wheel Alignment Operations - camber, caster, toe, steering axes and more
- Wheel Bearing Quick Test
Old Aug 2, 2009 | 10:40 PM
raymond g-'s Avatar
99 E320
i spotted 42 errors. anyone else?
Old Aug 2, 2009 | 10:43 PM
mleskovar's Avatar
'17 Jaguar XF
I only found 41 )-:
Old Aug 2, 2009 | 10:51 PM
Lancer
Just click on the browser again and hit enter. I hope the links would help..
Sorry for the error guys.
Old Aug 2, 2009 | 11:28 PM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
Angry I found 403 errors
Forbidden
You don't have permission to access /AbsSafety on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.41 Server at www.garage411.com Port 80
Old Aug 2, 2009 | 11:38 PM
mleskovar's Avatar
'17 Jaguar XF
Weird....if you scroll down to Post 1 in the Reply to Thread frame, then the links work. The few I looked at were informative.
Old Aug 6, 2009 | 09:54 PM
Lancer
hello guys.. the links are working fine now.. thank you..
Old May 19, 2012 | 10:10 AM
vettdvr's Avatar
03 E500 and Corvette
Originally Posted by am_beagle
Forbidden
This is what I got also today under starter
Old Mar 2, 2015 | 12:51 AM
Tall Paul's Avatar
2002 F-350, 1999 E55 AMG, AMG Orphans Club International Member #118
Still don't work
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
