Looking place to buy pad / rotor set
Old Nov 28, 2009 | 12:38 PM
urbancoyote's Avatar
e320
i have seen all kinds of brakes advertised and heard some are not good and will make noise.
Has anyone used "red stuff" brakes. Where can i buy brake sets. I can put them on or have my local mercedes mechanic do them.
Old Nov 29, 2009 | 09:07 AM
vettdvr's Avatar
03 E500 and Corvette
I have stayed with OEM parts purchased through a supporter of this site and had great results. But if you want?? "red stuff" brakes I don't know where to tell you to look.
Old Nov 30, 2009 | 08:42 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
I agree with vettdvr but I went with Porterfield R4-S pads (street performance) and Brembo "Aftermarket" (OEM replacements) rotors. My motivation was that the Porterfield pads throw less dust and are easy on rotors.
Regards,
paul...
Old Dec 28, 2009 | 12:39 PM
Benzo 003's Avatar
2008 ML350 4matic
Guys in the GL and GLK threads are hyping up Akebono Euro pads and Rotex Gold.....I personally like Brembo rotors....
Old Jan 13, 2010 | 06:28 PM
Topless2000CLK's Avatar
2000 CLK Cabriolet
Some info I found helpful:
http://www.brakeandfrontend.com/Arti...dge_codes.aspx
Below from this site: http://www.shotimes.com/brakes/survey/brakes5.html
This two letter edge code mandated by the DOT, and painted on all street legal brake pads, will give you some indication of their ability to resist fade. But only if you know how to read them. However, because of the wide range involved in each letter, it is only a rough indication.
Explanation of D.O.T. Edge Codes Located on all Brake Pads Official D.O.T. Edge Code Coefficient of Friction (C.F.)
@ 250 F and @ 600 F Comments
EE 0.25 to 0.35 both temps, 0-25% fade at 600 F possible
FE 0.25 to 0.35 @ 250 F, 0.35 to 0.45 @ 600 F, 2% to 44% fade at 600 F possible
FF 0.35 to 0.45 both temps, 0-22% fade at 600 F possible
GG 0.45 to 0.55 Very Rare
HH 0.55 to 0.65 Carbon/Carbon only.
O.K. up to 3000 F where it glows Notes: These edge codes are located on the edge of the friction material of every brake pad by government regulation, along with some other codes. The first letter is a grading of the C.F. at 250 F and the second letter is a grading of the material at 600 F. Each letter grade can actually have quite a range of C.F. But a difference in the letter grade from medium to hot temperature could be an indicator of fade. The letters can be in any order. Therefore FE pads fade when hot, and EF pads would not grab when cold.. Also, you should know that Steel on Steel has a C.F. of 0.25!! So EE pads have only marginally more torque than no pads at all! Therefore FF pads are usually considered the minimum for a high-performance pad.
