Plug Gap, '02 CL500
Old Feb 11, 2010 | 07:56 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Plug Gap, '02 CL500
I'm ready to install a set of Bosch 7422 plugs in my '02 CL500. Can someone tell me the proper gap? It is not on the under hood sticker. All it says there is:
"Tune UP Info: No adjustments required".
Old Feb 11, 2010 | 12:12 PM
lkchris's Avatar
'10 CL550, '12 GL550
Plug gapping has been gone from German cars for decades.
Your car should be fitted only with OE plugs, which will be properly "gapped" right out of the box. They will be platinum plugs, but OE platinum have zero/zip/nada in common with Bosch platinum plugs designed for sale at KMart. All you can do to any of these plugs with a gapping tool is break them.
Even when Mercedes used conventional plugs, they came correctly gapped right out of the (Bosch) box and the factory-set gap was printed on the box. Still is for these older designs.
Old Feb 11, 2010 | 02:56 PM
Jud Chapin's Avatar
Thanks for the response. IMO, though, a plug should never be installed w/o checking the gap and I just cringe when I hear someone say they install plugs right out of the box w/o doing so. It's a long way from the factory and anything can happen including someone dropping the plug on the floor, it being handled by a disgruntled employee, and/or it being damaged in transit. In any event, rest assured the Bosch 7422 plug is a direct replacement for the Bosch F 8 DPER plug that came with many '02 CL500s but is no longer available. MB shows the gap for this discontinued plug at .039.
Out of curiosity, how do you break a spark plug by adjusting the gap? I've been adjusting gaps on spark plugs for over 50 years and maybe I'm just lucky, but I've yet to break one.
Old Feb 11, 2010 | 06:29 PM
MBtech1098's Avatar
10 speed bicycle
They are gapped right out of the box, but I always double check to be sure...right out of the box, they are usually around .040 +/- a few thousandths.
Old Feb 11, 2010 | 07:54 PM
Jud Chapin's Avatar
Thanks...
Old Feb 12, 2010 | 09:30 AM
vettdvr's Avatar
03 E500 and Corvette
GAP
For MB plugs I check but don't set them. I have found a box that was apparently dropped with the ground electrode touching the spark tip. Had I not checked it it would probably have misfired.
So I check the gap but for damage more than opening size.
Old Feb 12, 2010 | 11:24 AM
Jud Chapin's Avatar
Yes, I'm sure it would have misfired as there would have been no spark to ignite the fuel mixture.
