Help Please
Old Apr 16, 2003 | 07:34 PM
SugeNert's Avatar
1998 c280
Help Please
i had originally posted this in the c-class (w202) forum but it may be better here
ok i have important question any help is appreciated.....
i am new here i have a 1998 c280 and my moonroof has what i percieve as serious problems...when opening it goes in very short intervals and it takes three times of letting off and having to hit the button again to get it open and then when i try and close the sunroof it wil not close @ all no sound nothing just does not work...i am guessing this may be a relay or some sort...i have brought the car to a shop and they had said everything was fine and it was for a day and since that day it has been screwed.....please help
thank you
man with tired arms
Old Apr 16, 2003 | 09:31 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Try synchronizing the sunroof. Hold the switch in the tilt up position for a few seconds, then hold it in the tilt down position for a few seconds. This alone might fix the problem.
Old Apr 16, 2003 | 10:19 PM
SugeNert's Avatar
1998 c280
is there a certain time i should do this or just @ anytime??? thank you again
Old Apr 16, 2003 | 10:44 PM
230KBenz's Avatar
'03 C230K
Why would they say everything is fine if the roof doesnt close? What you might need to do is pull or push the button up/down to close it instead of pushing it foward, once the roof reaches the full open or full closed position then continue to hold the button for 2 or 3 extra seconds.
2003 C230K magma C5, C7, 6 spd.
Old Apr 17, 2003 | 03:02 AM
mbtech208's Avatar
Between noon and 1 pm is the best time to try it.:p
Old Apr 17, 2003 | 10:23 AM
SugeNert's Avatar
1998 c280
thANK YOU EVERYONE THIS DID THE TRICK
