Critical Problem: Engine shuts off at low speeds
Old Nov 15, 2010 | 05:36 PM
customcdseller's Avatar
(crossposted on W211 and Tech Talk)
Car is a 2007 E350 with about 2k miles left on the warranty. From time to time, when I'm creeping along at low speeds (think pulling away from a stop sign), the engine will die. Loses power steering/brakes, but radio and electronics stay on. The electronics may have also died when this first started, but the most recent time, they did not. I coast/brake to a stop, shift into park, and the car starts up without drama.
The dealer looked at the car a few months ago, performed load tests, stated no codes were thrown, and gave an OK. The problem did not manifest again until this weekend, when it happened three times within a two mile drive home. The day before, a CEL had popped up and disappeared, which the dealership attributes to a cam shaft sensor. The car was towed to the dealership and again, there is no obvious source for the problem and they are taking no real action besides fixing that cam shaft sensor and driving the car for about 30 miles.
Could this have caused the whole issue? I'd hate to be in my car if this occurred at speed....
Old Nov 21, 2010 | 11:01 PM
bambu1's Avatar
clk350
Mercedes 350 CPS and/or balance shaft problem
Hi,
You might want to "search" this website for two problematic issues affecting vehicles built between 2005 and 2008 that have the 350 [aka 272 and/or 273] engines:
1. Crankshaft Position Sensor (CPS)
2. Balance Shaft Issue...this problem is huge, and seemingly kept hush-hush by Mercedes. Here's a must-read link: http://www.peachparts.com/shopforum/...d.php?t=271866
Number one will cost $50 in parts and around $300 for MB to fix. Number two will run you over 5-thousand if out of warranty.
Good luck.
Old Nov 22, 2010 | 11:18 PM
lkchris's Avatar
'10 CL550, '12 GL550
There's a DTB (dealer tech bulletin) which everyone else calls a TSB published on this, so it's hardly "kept hush hush."
Old Nov 23, 2010 | 11:14 AM
bambu1's Avatar
clk350
lkchris,
I purchased a CPO clk350 with an engine serial number that falls into the range of those affected with a defective balance shaft. Mercedes knew about it, the dealer knew about it. But the consumer (me) was kept in the dark until I raised the question having subsequently read about the class action suit regarding the balance shaft problem. The MB tech informed me that eventually they'll need to remove the engine from my car to replace the part! If I knew that was a potential problem, I'd have passed on that model vehicle. Who would knowingly purchase such an auto knowing that the engine will most likely need a partial rebuild within 100K?
A known major engine flaw has been passed on to consumers without any fair warning by the manufacturer or the dealer. They had the facts but kept it quiet. At the very least, in my opinion, this is an unethical business practice.
tx
Old Nov 29, 2010 | 02:57 PM
unit2motors's Avatar
Sprinter
The 350 cdi v6 engine is effected with the balance shaft fault. the fault is the cog that the timing chain runs on wearing, becoming smaller and changing the engine timing. this then gives a cam sensor fault. If left untouched it will develop a noise..
The 350 petrol engine has a Crank shaft sensor fault this will cause the engine to cut out when warm...
Old Nov 29, 2010 | 08:34 PM
Update: Car exhibited a similar problem today multiple times, each time shutting off in rapid succession within a few seconds of each other (basically bucking like an animal). CEL illuminated and I'm pretty sure I'm leaking some fluid. Waiting for another tow....thank you for all the information above. I will bring it up to the dealership.
Should have bought a second Porsche....
Old Nov 30, 2010 | 04:12 AM
jemfrap's Avatar
c230
damn thats just bad luck. I have a buddy who had his engine go to crap.
Old Dec 2, 2010 | 08:22 PM
Frozensolid's Avatar
95 202
Originally Posted by bambu1
lkchris,
tx
I agree, at the very least Mercedes should extend its warranty for this issue
