Is Centering the Steering Wheel DIY?
To center it take the airbag off (careful!!) unplug its ignition wire, and loosen the central bolt (approx an 8 milli meter allen screw) pull the wheel towards you and put it back on in the right position. The connection of the wheel and the column is made by a multi teeth connection (sorry but I dont know the perfect English word for this) which allows locating the wheel in approx. 10 degrees steps.
The steering wheel can easily be centered. However first check the reason for the wheel being off center. If the alignment has been reworked it could be off center, but also if the alignment experienced severe hits from potholes or sidewalks. In this case centering does not help much.
It is correct that there are splines, however, there is a "keyed" spline so as though the steering wheel can only fit in one position. I have removed many late model Benz steering wheels and this is what I have seen every time. The alignment must be checked to properly fix this situation.
