Having starting problems but runs great after it starts
What do you think could be the problem?
I hooked up a fuel pressure gauge to the Schraeder valve on the passenger side manifold and read ~40 psi at idle. When I revved the engine the pressure dropped to ~30psi. I understand that the fuel pump is rated for 110psi. I'm guessing that the fuel filter/regulator may be the issue and will be checking the fuel pressure upstream and downstream of it.
Does anyone know what the fuel pressure at the manifold should be?
Thanks for your help! This forum has helped me MANY times.
Anybody have access to that TSB?
