Sunroof Cable Problem
I am replacing the sunroof cable on an 88' 300E and things were going fine until I started to remove the old cable. I follow the workshop manual and when I pull the old cable out after using the motor to push it as far as it would go, the cable comes out only about 25-30 inches and then it stops. It seems to get stuck somewhere inside the tube that the cable rides in. Anyone has any idea on where it's getting stuck and how to remove it? Thanks.
Most of the time, I found out the plastic gear inside the sunroof drive is stripped and the cable is fine.
