Recommended Tire Pressures - Where?
The 2011 Manual says on pg.266:
you will find a table of recommended tire pressures on the Tire and Loading information placard on the B Pillars on the Driver Side.
You will find a table of tire pressures for various operating conditions on the inside of your vehicle's fuel filler cap.
However, the info @ each location contradicts each other with:
the fuel cap saying:
33F/33R Normal Load
35F/39R Heavy Load
the door jams has 2 placards saying the same but without load suggestions:
35F/39R
See attached to see pictures in same order as describe above.
https://mbworld.org/forums/4899912-post15.html
What is the right PSI?
"The tire pressures in the tire pressure table on the inside of fuel filler flap are valid for all approved tires installed at the factory, unless stated otherwise."
"Tire pressure table for all approved tires installed at the factory"
"You will find a table of recommended tire pressures on the Tire and Loading information card on the B-Pillar on the driver's side (>Page 274). You will find a table of tire pressures for various operating conditions on the inside of your vehicle's fuel filler flap."
So last I knew my tires were installed @ the factory. While the second statement above say to look in both places.
I am still
Cheers,
Jeff
Given all of the typos & conflicting information in the manual, it is suspect at best.
When in boubt, 35psi works.
Wayne
Keeping a little spare air in all of his tires.
Also if you look at the tire very small small prints it will tell you the psi
People, you're making a Himalayan Mountian out of a molehill. If you are really bothered about this and you won't believe folks who have been using the information on the fuel filler door (my wife even knows to use that info.), call MBUSA. Who knows, you might be more confused after speaking to them.
Wayne
35 psi or stay home.
Putting this to bed.
I was right about MBUSA not helping.
Wayne
Occasionally smarter than the average bear.
