Serious V I B R A T I O N S !
I and the mechanic know that it's cylinders 3 and 6 since we had my engine hooked up to the computer. Everytime I shift into "P" and "N," I don't feel the vibrations onto my steering wheel. But in "R" and "D" the vibration is really bad when the car is stationary. As soon as the car's engine revs up past 1000 rpm's the vibrations disappear and everything is smooth. The mechanic did ask me if I high rev my engine a lot during heavy acceleration and I replied yes.
Does anyone know what the solution is to this problem and how this vibration problem started that I could feel on my steering wheel?
Your Answers and insight are appreciated....
My $.02
First and probably most accurate, he's full of it.
Second and just a guess, you could have an ignition problem. I had a bad set of plug wires in a car that cause misfiring at certain engine speeds. The theory is that resistance changes as cylinder pressure cheanges with RPM. Leave it in D for a while and then have a look at the plugs.
Third and another guess, you have bad rod bearings on those 2 rods. As RPM drops, so does oil pressure and the thin film of protection gets squeezed out.
The ignition wires were also arcing to ground, which didn't help. I renewed those as well.
