Adding Slick 50 to a CLK 430 Engine- Do or Don't?.
I have read that it can be harmful in some engines versus the benefits.
Thanks in advance for the feedback.
Teflon is great stuff when used properly...but not IN an engine.
Most all of that stuff is garbage. Give your money to charity rather than wasting it on that stuff. Could be harmful I guess. MB says no additives.
That's what I thought. No additives. Just regular oil changes every 5,000 miles with name brand oil or 100% Synthetic (ideally SuperSyn by Mobile 1) every 12,000-15,000K miles.
Thanks.
No one reccomends stretching out your oil change intervals to 15K like Mobil 1 advertised when they first released their synthetic oil about 20 years ago. Some people advocate changing your oil every 3,500 miles, even if you are using synthetic. Others say that if you use dino oil, you should change every 3,500.
I follow MB's reccomendations & change every 7,500 with synthetic. If you have an older car that has not been run with synthetic, changing to synthetic with its superior detergents and lower viscosity can cause "false oil plugs" to desolve and cause new onset of oil leaks. I had this happen to me twice w/ older MB's so I don't not switch from dino oils to sythetics.
here read this.
http://www3.ftc.gov/opa/2001/02/zmax1.htm
i think you will find this interesting.
Last model year for the w208 cab, there still may be som,e around.
I ran my C280 on the dyno with Mobil 1, 5-30wt and after some baseline runs added the Oil Extreme and picked up 8Hp.
We found that on our Superbike motors the stuff helped the motor stay fresher a little longer with better ring seal over time. Cam lobes and buckets also looked very good.
I learned about the Oil Extreme from David Vizards website which I don't think still exists. It was called Motortec.
Jeff
If you put any type of these oils into your car, you risk destroying the engine.
Can someone share their comment on using Slick 50 or any other Engine oil additive in a MB engine? I have a 2003 CLK 430 Cab with 15,000 Miles.
