Intermittent Starting Problem - MBtech208, anyone else??
Old Aug 9, 2003 | 12:06 PM
nickv's Avatar
Used to be a CLK430
Okay so every once in a while, especially when the car is warm, it hesitates before starting. Meaning after I click the key to the right, the car will just sit there and try to start, but will take a good 4-5 seconds to 'catch'.
So today I started the car after it sitting for a week and it fired up like a champ. Went to the video store (4 mile drive) and when I came back out, the car was doing it again, except this time it didn't catch, tried again, nothing, and 3x more times, nada! Gave it time to contemplate starting, and on the 6th try it started. Any idea is going on??
This only happens when the car is hot, I'm confused and the dealer doesn't have a clue. I only have 250 miles left on the warranty...any ideas??
TIA!!
Old Aug 9, 2003 | 10:10 PM
f4i 954's Avatar
2009 e class 2012 ml350
What engine, does it make any noise?
If you have a 112 or 113 engine, it may be the starter motor.
They have to apply lubricant to starter motor & fly wheel teeth.
Old Aug 11, 2003 | 10:31 AM
nickv's Avatar
Used to be a CLK430
It is the 4.3 liter V8, the only noise is the cranking noise.
Thanks!
Old Aug 28, 2003 | 08:32 PM
nickv's Avatar
Used to be a CLK430
BUMP!!! Where has everyone gone??
Old Aug 29, 2003 | 08:02 AM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Hot start problems may have several causes, but if your shop does not have a clue get another one. For a qualified shop hot starting problems are just one of the simplest things to get rectified.
Just from remote a few causes:
+Cold start valve gets (wrongly) a signal to enrich the mixture
+Cold start valve is leaking fuel
+temperatur switches activating the starting controls submit false values
+air mass measurement wrong
+leaking injection valves
+CO value wrong (O2 sensor??)
and a few more
Old Aug 30, 2003 | 06:55 AM
patrick's Avatar
Originally posted by bamberger_1
...Just from remote a few causes:
and a few more...
Pardon me,...but I do not think any of these will cause the problem!
And...where is that cold start valve located?
Old Sep 1, 2003 | 06:09 AM
Talking
Whatever you say !
Old Sep 2, 2003 | 06:17 PM
nickv's Avatar
Used to be a CLK430
I just replaced the battery and the problem seesm to be gone!!!
