SL55 AMG
Old Jun 14, 2013 | 02:44 PM
hlmpk's Avatar
2003 SL55 AMG
SL55 AMG
Hi Guys,
Can anyone show me how to hold the retractable top half opened? (it is trying to come back down
I need to keep it staying that way for a little while, so I can work on some part of it...
hlm
Old Jun 14, 2013 | 08:15 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Ignition on (position 2), operate the switch to raise or lower the top, and release the switch when the top is in a position that allows you to access what you want to work on then turn the ignition off. The top will stay where it is. That's what I did when I needed to replace a damaged trim piece (one of the "flaps" that form the rear deck when the top is down).
Old Jun 17, 2013 | 08:50 AM
hlmpk's Avatar
2003 SL55 AMG
How to Hold the Retractable Half Opened
The difference in what I did is I did not turn the switch off, so after a little while, it is coming back down -- pretty dangerous when you have your fingers around...!
OK, I will turn the switch off.
But is there a place you can stick a piece of wood to hold it, just as a precaution (like when you raise the car with a jack, and also insert a piece of wood to prevent the car accidentally coming back down)?
hlm
Old Jun 17, 2013 | 10:01 PM
pdjv's Avatar
If your top won't stay in one position when it is partially open, the switch released, and the ignition off, there's something else wrong. There's a vario roof guide here somewhere - it might be worth looking it up.
The alignment of the top is fairly critical - trying to use a block to keep the top from moving is probably not a great idea.
Old Jun 18, 2013 | 10:18 AM
hlmpk's Avatar
2003 SL55 AMG
OK, I will look it up.
Thanks for your info.
