I need ALL information regarding the V12 (w140)
Whats the enginecode? (the 408 hp and 394 hp engine)
Engine weight? (w/wo aut gearbox)
Durability? (when tuned)
Gimme all you got!
Gimme all you got!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
96 S600C
I have a 1996 S600 Coupe W140.
Twin-DOHC 48-valve, all-alloy V-12
389HP
420 ft lb torque.
Compression ratio 11.0:1
Transmission 5-speed driver adaptive electronic automatic.
Rear axle ratio 2.65:1
Bore x Stroke 3.50x3.16 in/89.0x80.2 mm
Maximum engine speed 6,000 rpm
Alternator output 14 V/143 A
Battery rating 12 V/100 Ah
Fuel capacity 26.4-3.3 tank-reserve/100.0-12.5 gal/l
Oil capacity 10.7 qt/10.0 l
Coolant capacity 21.1 qt/20.0 l
Is there anything else you would like to know?
I do the recomended maintenance.
389HP
420 ft lb torque.
96 S600C
I have only had the car for 6months. When I bought it it had 44600 miles on it. The prievious owner only put 22000 miles on it in 6 years. Now it has 55000. Only problem I have had (knock on wood) was a transmission leak. which just required the replacement of a couple of O-rings ($600). I currently have one issue with the seatbelt extender on the drivers side, the gear is stripped and I dont want to replace the entire motor ($638.00) for a plastic gear. I am waiting on a company that makes a replacement for this plactic gear for the W126 coupe but has not finished developing it for the W140.
This is my daily driver.
96 S600C
Engine code I believe is 120. I would need to check some documentation I have at home to be sure.
I have never seen the engine weight listed anywhere.
I was told that the engine alone new cost $42000.00. Dont know how accurate that is.
Durability? Have never found any long term testing of this engine or car. I would like to see that information also. Everyone I talk to says that the engine should last 300,000 miles easy. But where is the proof.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
96 S600C
The torque is good but if I wanted it to be better I found that PowerChip makes an upgraded chip that will take the engine to 420 hp and 449 ft lb torque. The cost is $840.00.
96 S600C
I am not planning to make any mods like that to mine. I will save the $840.00 and put it toward my saving for an SLR
The air filter is about all I will do. Other than that I will keep it stock.
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
