install Europe Maps on US comand NTG4.5
I need to change lights to UK spec etc and radio tuner, but for now am just tryign to install the UK/Europe maps.
I was told just get the right disc and PIN and all would be simple.
However when I put the disc in, comes up with incompatible message (see attachment)
Is there any cure for this please? hopefully wont have to swap out the comand unit. I do have xentry and access to online coding if needed.
thanks
You need to change region coding in Comand Dealer menu.
Press "END call" + "#" + "1" approx for for 10 seconds until menu comes. If I remember right go to 7. HW Setting - Market/DVD setting and here change region from USA to ECE. After that press "ON" for 10 sec until Comand restarts
I managed to install the europe maps on both the ML350 and the E350.
First I had to change the region as mentioned above. Then I used the europe disc I purchased for around $80, same disc for both cars. Finally I bought a PIN for each car from a different forum member, was much cheaper than buying the PIN from Mercedes.
Took around half hour for each car to install the europe maps and they both worked flawlessly.
hope this helps
Terry
hope this helps
Terry
Will installing the Europa map, overwrite the NA maps, or they will be installed alongside?
How much did you pay getting the pin per installation?
hope this helps
Terry
I am having similar issue. I imported ML 350 (W166) from Canada and I want to add maps for Europe. I spoke with a Mercedes dealer here in Bulgaria and they told me it is not possible on model older then 2015. I have already changed the Region settings to ECE and I am about to get a disc with the maps. Can you tell me where you bought the PIN from? If you can send me an email at dim.shatarov@gmail.com it will be much appreciated. The current version of the North America maps is 2012 (V 7.0)
Cheers,
