Dashboard Tire Pressure Indicator vs. Tire Pressure Gauge
Old Nov 8, 2017 | 12:59 PM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Which is more accurate, the tire pressure indicator in the instrument cluster, or an inline tire pressure gauge? Mine disagree and I'm wondering which I should trust.
Old Nov 10, 2017 | 08:08 AM
Mr. Toad's Avatar
BUMP
Old Nov 10, 2017 | 08:16 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Tire pressure gauges
I have noticed the same thing too but normally only 1 or 2 lbs difference. If you drop your tire gauge, it could damage it and cause a faulty reading. Buy another tire gauge and get a quality one and see how it compares. Alot of people just use the cheap plastic tube type, I would invest in a metal tube type or one with the round dial. Good luck.
Old Nov 13, 2017 | 09:45 AM
Mr. Toad's Avatar
I have two gauges - a round, dial-with-needle type and a brass tube one. They both tend to indicate a 2-3 pounds more than the dashboard readout.
Old Jun 10, 2019 | 03:39 PM
Dutch2's Avatar
2019 E450
I think I didn't make myself clear.
The sticker says 33 psi.
The low pressure warning on the display says a tire that is 40 psi is OK, and that a tire that is 37 psi is low!
I used a gauge to measure the tire pressure and the tires are close to the pressures displayed on the warning screen.
D.
Old Jun 10, 2019 | 03:59 PM
whoover's Avatar
'19 E63S sedan
D.
It's responding to the difference between pressures on one axle. Just set all tire pressures to where you want them with your gauge and restart TPMS. To be safe, set them all to 33 as per the sticker, restart TPMS, and then change the pressures to what you want.
Old Jun 10, 2019 | 05:05 PM
Dutch2's Avatar
2019 E450
How is 39 psi OK and 37 psi is not if the recommended pressure is 33 psi?
Old Jun 10, 2019 | 05:32 PM
whoover's Avatar
'19 E63S sedan
I believe it's calling your attention to the fact that you have a 2 PSI imbalance at your rear axle. That's an easy enough theory to test.
Old Jun 10, 2019 | 09:16 PM
Isawelvis's Avatar
Veteran: Air Force
There is a way to reset the values ie adjust the desired airpressue you want to maintain in the tire. If you wanted to you could make them all 39 PSI and it would be the base setting. I just google this and found out how to do it.
Old Jun 11, 2019 | 03:55 PM
Dutch2's Avatar
2019 E450
I think I have it figured out...
It has nothing to do with an imbalance in pressures or anything like that.
The car simply records the tire pressures when you reset the system. When the pressure is 3 psi below the pressure you told the system is "normal", the warning pops up.
The driver side door jamb sticker says 42 psi, I believe this is the maximum pressure. Whoever checked the tires (at the dealership!) must have though that was the normal pressure, filled the tires to 42 psi, and reset the system. That is why a 40 psi tire was OK and a 39 psi one was not.
I let some air out of the tires until they were all 33.5 psi and reset the system. All is well.
D.
