Turbo UnderBoost Condition P0299
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
I am currently driving 2014 E550 M278
Recently, It got code P0299, under boost condition.
The car drives fine from cold start, but throttle starts to get weaker after 20-30 mins of driving.
Then, it will go under boost condition. Code P0299 with CEL light up.
If I go aggressive driving, it will go under boost faster.
I thought, there must be boost leak somewhere.
Dropped the car to the shop here for a check up.
The tech scanned the car, found bank 1 turbo (Passenger side) is having under boost issue.
He unplugged vacuum hose from wastegate actuator, and there is quite a bit oil dripped out from actuator and hose.
He traced back where the oil is coming from. He found my brake vacuum pump is leaking.
I am wondering, is this possible ? brake vacuum pump oil leak all the way into wastegate actuator ??
And is this the real cause of underboost code ??
Yes, i found the issue.
My driver side turbo wastegate vacuum hose was broken.
Now, i have patched them up. it is normal now.
Underboost, either vacuum hose is lose. Or one of turbo is not working properly.
Hopefully, this can help you.
Ddevonaldnb1 (10-21-2023)
Need help
Received 1,786 Likes
Well, unless you are good working on your car, you probably will need to take it to a shop.
By default, the wastegate actuator is normally held closed by a spring. The boost pressure line opens the wastegate when there is excessive boost. However, if the actuator spring has weakened, the wastegate may open sooner, resulting in an underboost condition. If there is a tear in the actuator pressure hose (usually rubber) and not enough pressure acts on the actuator, you may have an overboost situation. This may put you in limp mode to protect the engine.
The whole oil leak thing is troubling. If the turbo is leaking oil, the bearings may be shot and oil is leaking past the turbine shaft. But again, I don't see how that turns into a visible leak under the car.
If the answers given by the OP don't help, you should get a capable professional to tell you what is going on. (By the way, if the brake vacuum pump was leaking oil, I don't see how this causes the underboost problem.)
Mr. Toad (09-25-2023)
First, where did you have the car checked and how much did they charge you?
Did you find any coolant in the engine bay or smell it. Coolant has a very distinctive smell. You did not mention low coolant before.
Are you being told that your radiator leak is allowing oil and coolant to mix? Or are those separate conditions?
It's easy to check if the turbo(s) are shot. Remove the air inlet hose coming from the air filter to the turbo and spin the turbine (compressor wheel) by hand. If it turns smoothly and easily, and there is no play in the shaft, then there is nothing wrong with the turbo. Here's a couple of diagrams. On my engine, M276, the turbo housing and exhaust manifold are one piece. Not sure how they are on your engine, but you should be able to find a rebuilt turbo for far less than $7000. (By the way, if you can get a new M278 for $7000, please let everyone here know. Just be careful that you are buying a complete engine and not just a block and head. If that's the case, you won't get turbos with it.)
Actually, it looks like the turbos are separate from the exhaust manifolds on your engine. That should make it easier to check and replace/repair, if necessary.
As you can see, on the M276 DE30 (3.0 liter turbo) engine, the turbo and exhaust manifold are a single piece.
