GL 450 Oil Leaking on Wiring Harness??
Old Aug 23, 2022 | 09:44 AM
Mr. Toad's Avatar
2016 E400 Coupe (C207)
Please forgive my ignorance; I have been reading various related threads and find myself very confused.
I have a 2016 E400 coupe (C207), which I believe is the M276 engine - is that correct?
The "Camshaft Control Valve Solenoid" part number on my engine is 276-156-07-90, which replaced old part number 276-156-04-90. Is this newer, replacement part designed to address the oil-in-the-wiring-harness problem, or is my engine still susceptible to this?
Old Aug 23, 2022 | 09:58 AM
chassis's Avatar
2017 GLE350 4MATIC
I have a 2016 E400 couple (C207), which I believe is the M276 engine - is that correct?
There is no documentation that MB “designed the latest parts to solve” the leak issue.
Posters on this site seem to have fewer/no problems with the latest part number in the EPC system.
Old Aug 24, 2022 | 03:45 PM
Mr. Toad's Avatar
Can anyone tell me the orientation of the wiring connection on the old part number 276-156-04-90? My engine has the revised 276-156-07-90 part and the plugs connect at the top of the Camshaft Control Valve Solenoids. I'm just wondering whether the point (e.g., top, side, or bottom) at which the wiring connects to the solenoid might have an impact on the potential for leaked oil to creep into the harness.
Old Aug 25, 2022 | 09:33 PM
chassis's Avatar
2017 GLE350 4MATIC
I don't understand the question. Replacement sensors or magnets install only one way - the factory way. What am I missing?
The theory on the table is that the cam position sensors fail by allowing oil to escape the sensor body, onto the sensor pins. From there the oil migrates to the harness terminals, and via capillary action into the harness.
Gravity does not play a role in capillary action. Capillary action is what transports the oil from the failed sensor to the ECU, injectors and O2 sensors.
Old Aug 26, 2022 | 07:57 AM
tpenziner's Avatar
SLK
A lot of great info in this thread... I'm going through this now with my 2015 S550 Coupe, I had purchased it last month with 40k miles, lucky for me the dealer is covering it all, I'm told it's close to a 9k job since they have to pull the engine out.
Old Aug 26, 2022 | 08:41 AM
Mr. Toad's Avatar
As noted in my previous post, my engine has revised part # 276-156-07-90 (Camshaft Control Valve Solenoid), which replaced old part # 276-156-04-90. The redesigned part mounts with the electrical connecting plug facing up. I don't know what the orientation was on the old part, and I was simply asking whether the upward orientation might impact oil ingress into the wiring harness.
Old Aug 26, 2022 | 11:21 PM
  #32
chassis's Avatar
2017 GLE350 4MATIC
Oil escapes from the engine via a failed sensor or solenoid. It then migrates through the harness via capillary action. Capillary action is unaffected by gravity. You are asking if gravity affects oil migration. Gravity does not affect oil migration when the mechanism is via capillary action, as it is in this case.
Do you hold the belief that the original part had an orientation different than the part in your engine?
ebay E400 engine shows solenoid connector "up" orientation. No way of knowing if the solenoid is factory or not.
https://www.ebay.com/itm/35369780447...Bk9SR5TlmdXbYA
Old Aug 29, 2022 | 07:58 AM
  #33
Mr. Toad's Avatar
I don't know about the orientation of the original part, hence my question. As they decided to replace the original with a redesigned version, I'm wondering if perhaps the positioning of the connector was part of the revision. On my engine, the connector is at the top of the solenoid as seen in the picture you attached.
Old Nov 2, 2022 | 04:48 PM
  #34
s550hollywood's Avatar
2013 s550
Originally Posted by KatBatt
I just received same msg on my 2013 S550 today. It only has 24,100 miles on it.
Did oil leak from your cam sensors or cam magnets into the wire connector and harness or your 2013 S550? I have same model.
