sunroof lube
Old May 27, 2004 | 11:06 PM
charliev68's Avatar
2000 CLK430
sunroof lube
instead of buying the mb stuff from the dealer to lube the rails i used mobil 1 grease/lube from the auto parts store. i put it on and so far it is working fine.
any opinions on this? did i royally mess up my car or is it okay?
please help.
Old May 27, 2004 | 11:11 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Re: sunroof lube
please help.
It'll be perfectly fine. You could have used KY Jelly and it would still be fine. Mercedes lube is nothing special, it just has the star on the jar.
Old May 27, 2004 | 11:19 PM
charliev68's Avatar
2000 CLK430
thanks dave!
Old May 27, 2004 | 11:30 PM
BudC's Avatar
2011 E550, 2013 GLK
Re: Re: sunroof lube
I don't say you have to use Mercedes-Benz Gleitpaste on the sunroof but it isn't just a run of the mill lubricant. I've been using it for years to cure all kinds of lube problems that nothing else seems to fix.
Since Gleitpaste is so expensive, dealers and Independents may use something cheaper like a spray that Audi dealers use.
BTW, Gleitpaste comes in 500 g cans, but you can buy small containers of the stuff from some Internet parts outlets like Rusty Cullen's BuyMBParts.
http://www.buymbparts.com/
Old May 27, 2004 | 11:56 PM
mbtech208's Avatar
Which is the Gleitpaste? Is it the white paste, or is it the yellowish thick glue-like substance? The lube I use for the sunroofs is the glue-like lube, I've never tried using the paste. The paste works good for stopping leather rubbing noises (squeaks).
Old Mar 9, 2018 | 01:35 PM
GreyGhost2015's Avatar
C400
Sunroof Lube
Found this seems like it might be the product that Mercedes is using http://www.chestertoncompany.com/GER...ct%20Datasheet
