Mercedes engines--unrefined at idle??
Old Jun 18, 2004 | 02:32 PM
akbro93704's Avatar
2014 C250 sport
hey!
I've noticed that all newer Mercedes models (except the V12's) have a noticeably rough sounding, almost diesel like idle. I've noticed this on some of my family members Mercedes (ML55, E320's, SL500, ML320, CLK320, CLK430,S500...)..has anyone else noticed this and do you know a reason why they sound like this?? Just curious thanks!
Old Jun 18, 2004 | 02:53 PM
vraa's Avatar
Are you sure? Maybe somethings wrong?
Every Mercedes I've been (various 500's, 55's, and two 600's but one doesn't count because it's RENNteched) have an almost silent idle. The r230 is a little raunchy, sure, but then again it's supposed to be a sports car. The w220 was absolutley silent at around 500rpms I believe. It's almost amazing how smooth these cars are.
Old Jun 18, 2004 | 03:18 PM
akbro93704's Avatar
2014 C250 sport
ya im sure, as the miles were put on to these engines the idle got noticeable rougher...
Old Jun 18, 2004 | 03:40 PM
BoSoxFan's Avatar
2004 E500
This may seem like an off-the-wall response but since you are having the same problem on several vehicles: where do you buy your gas? I once had a rough idle on a Porsche and the dealer said, before you bring it in, try a can of injector cleaner since it might be dirty injectors. He recommended a product that was called something like CJ-44K (?). It worked wonders.
Old Jun 18, 2004 | 03:44 PM
akbro93704's Avatar
2014 C250 sport
Shell or Texaco gas, 91 octane. Before 1999, the DOHC 4-valve per cylinder V8's were very smooth at idle, but once Mercedes introduced the SOHC 3-valve per cylinder V8's, the idle got pretty rough. It could be the engine needs to be cleaned out with what you suggested, I should try it...thanks!!
Old Jun 18, 2004 | 03:46 PM
akbro93704's Avatar
2014 C250 sport
PS---I think granite grey is an awesome color , kinda irridescent
Old Jun 18, 2004 | 04:13 PM
BoSoxFan's Avatar
2004 E500
Thanks. I had a hard time deciding between the Pewter Silver and the Granite Grey but I'm really pleased with it. One of the things I really like is that it looks different under different lighting -- sometimes it seems to have some blue in it, other times green, or just grey. I've only had it a month and will put the first coat of wax on it this weekend. I'm curious to see how it shines up.
On the gas, supposedly all the majors use high quality detergents now. However, about 15 years ago, a dealer told me to use only Shell, Mobil, Exxon, and Amoco because of the quality of their detergents. Every time I used a different brand, the engine would run rough.
Another thing: here in the DC area, the daily commute is usually stop-and-go all the way. I would sometimes find that by Friday the car would be rough so I would take it out on the freeway on the weekend and run it at a lower gear than usual to blow all the crap out.
Old Jun 18, 2004 | 04:24 PM
akbro93704's Avatar
2014 C250 sport
thanks for the info! The engines run great at all other speeds except the idle, so I guess it's not that big of a problem, going on the freeway in a lower gear is a good idea though
Hows the 7-speed in your E-500??Do you know how many MPH is redlines in first gear??I'm curious...thanks!!
Old Jun 18, 2004 | 04:49 PM
BoSoxFan's Avatar
2004 E500
The 7 speed is awesome. The comfort/sport settings are perfect for city vs highway driving. With all those gear ratios, you never get into one of those situations like when you're doing 10-15 mph and even second gear won't give you the acceleration you need. It's great on the freeway: when you get an opening in traffic, you can shoot ahead without even doing a kickdown. It's still under 1,000 miles so I haven't pushed it to the redline yet. 150 miles to go and then I'll let you know.
Old Jun 18, 2004 | 07:08 PM
RJC's Avatar
RJC
Various
Most of the newer modular engines (MY99+) do have a rough idle when in park or nuetral but not when under load ie in drive. The condition is liked to a lean miss and I'm sure its due to emission concerns. These engines also have much npoisier valve trains compared to the 4valve DOHC previous versions. I'm sure MBtech208 can further enlighten us.
Old Jun 19, 2004 | 01:06 AM
DavidNJ's Avatar
'05 E320 CDI;'04 S2k;'94 Supra TT;'10 QX56;'38 Buick;98 Port City Offset Late Model
Unless a mechanical failure is occuring, the only thing that can cause the problem is fuel delivery or ignition.
Check:
Injectors,
Fuel Pump,
fuel filter,
O2 sensor
knock sensor.
iat sensor,
maf/map sensor (I don't know what MB uses),
ignition wires,
plugs (actually, the plugs can go a long way to diagnosing this problem),
coils
It sounds like a knock at no load (diesel sound at idle). Too lean? Faulty info to the ECU? Inaccurate ignition timing?
Is it a hot only or cold only problem?
Remember the ECU is plotting sensor inputs against lookup tables, so if the engine isn't doing what the ECU commands (injectors, fuel filters, fuel pump), or the ECU misunderstands what the engine is telling it (bad sensors), you have a problem.
This isn't a clearence problem, busted cam lobe, bad valve seat or guide, bad lifter, etc.
Old Jun 19, 2004 | 01:23 AM
akbro93704's Avatar
2014 C250 sport
thanks for all of the info, very helpful!! I don't think I am going to worry about it because the engine's run perfectly, just the idle is a bit crackly...thanks though!!
Old Jun 19, 2004 | 04:27 PM
RJC's Avatar
RJC
Various
Right. As i mentioned it's normal. When I got my first clk 430 in 99 I noticed the same thing and the dealership checked most of what the previous posted recommened. All was normal and I've had 4 new CLK's since my 99 and they all have the lean mis without load on the engine.
Old Jun 20, 2004 | 03:23 AM
akbro93704's Avatar
2014 C250 sport
ok cool...thanks everyone
Old Jun 20, 2004 | 03:26 AM
akbro93704's Avatar
2014 C250 sport
RJC---this is a weird coincidence--there's a guy that lives down the street from me, and he has a 2004 CLK500 EXACTLY like yours, and his personalized license plate says "RJC" on it lol
Old Jun 20, 2004 | 02:37 PM
RJC's Avatar
RJC
Various
That's pretty funny. Tell him the initials are copywritten and therefore protected for use on anything related to a clk500 :p
Old Jun 21, 2004 | 12:37 AM
akbro93704's Avatar
2014 C250 sport
:p sure,ill tell him!!:p
Old Jun 25, 2004 | 10:26 AM
tokomo's Avatar
CLK
Well, if you want to know, I have CLK 320 2000 and you can barely hear the sound of the engine on idle.
