722.9 P2767 limp mode after fix
https://mbworld.org/forums/s-class-w...ical-help.html
I DIY replaced the 2 middle speed sensors (from Amazon) in conductor plate - I am vary handy and professionally trained in electrical/electronics. After putting the plate and valvebody back before re-install ATF pan, I tested, with key in 2nd position w/o starting engine and foot on brake, and observed shifting P-R-D many times very smoothly, without harsh-shifting or almost crashing into gear. Now with everything re-installed, engine-started, it's still stuck with harsh/crashing shifting, only to R or D.
I cleared P2768 code with a Veepeak wifi OBD2 adapter and Fourstroke app, but it comes back soon after. is it because, some say, the generic OBD2 scanner is not good enough? has to be a higher-end scanner to completely clear the code?
any comments or inputs would be greatly appreciated. and Hope that what's happened to me and whats been done could be of referance to others as well.
Harry
Hope this msg helpful to someone tackling the same issue.
I need to tackle SRS next ……never ending.
