mbtech208...by disconnecting and plug the slk 230 vaccum line fuel pressure .........
1 Post
99' SLK 230 & 01' CLK 430
regulator, this will increase the fuel pressure because fuel can not return therefore the engine will recieve for fuel. Is this method is true.
1 Post
1997 Toyota Tacoma 4x4
Yes linh, that is very true indeed. By disconnecting the fuel pressure regulator vaccum line, you will disable the regulator and raise fuel pressure in the fuel rail. This will cause your engine to run rich, not pass emissions, have no gain in power, set all kinds of fault codes, possibly damage your engine due to a rich misfire, foul out your spark plugs, damage your fuel pump because of the added work it has to do, and God knows what else. Still want to try it out?
1 Post
mbtech208.....i like the way you WARNED me but really RICH is still safer the LEAN. Anyway, been there done that with my 91 MR2 Turbo. I melt the piston because of over boost and lean out the engine. I will take your's advice very seriously because it a $45,000 plus car not a $10,000 MR2 Turbo.
1995 Ferrari Spider, Porsche 911 Turbo,01 Hayabusa, 01- E55
mbtech208?
MBTECH208:
I am hoping you can shed some light on this.
NO one can find the fuel pressure regulator . How does the car richen the mix when it needs.
thanks in advance
--scott
thanks in advance
--scott
linh Are you on the MR2 Board?
NP
1 Post
Re: mbtech208?
Originally posted by Autostream
MBTECH208:
NO one can find the fuel pressure regulator on my 2001 e55. How does the car richen the mix when it needs.
I am doing a dry nitrous system and need to richen the mixture on demand.
thanks in advance
--scott
MBTECH208:
thanks in advance
--scott
Re: Re: mbtech208?
The fuel pressure regulator on your car is an integral part of the fuel filter.
1 Post
Re: Re: Re: mbtech208?
wow! Did you mean fuel filter or fuel pump. And so how does one richen the mixture on demand?
i only need to richen it at WOT. if there is a vacuum line there, it sounds like a standard fuel regulator setup and pressurizing the line should work.
omg, what an odd place to put a FPR- under the rear seat? Never seen that b4,geez!!
