Clean Power Supply for Programming
Anyone know of a good / cheap power supply with 100AMP?
So far I only find. Schumacher Inc 100 for $500 and Deutronix 1600 for $1000 and up.
I am using Xentry with Openport 2.0.
Best price I found so far
Around $300 - PowerMax PMBC-120-ADJ > 120 Amp 12 Volt Battery Charger
https://www.ecodirect.com/PowerMax-P...x-pmbc-120.htm
For Mercedes, 55amp power supply is enough. I have the INC100 and the powermax with 55amp output. Both work just fine. One thing I will tell you, programming with the OpenPort is not the best idea. Coding is fine but flashing is another story. I have tried it and just doesn't work.
Benzenator (11-29-2020)
Where is the amp output specified by Daimler? I haven't seen it any manuals or online so far. Does it just get specified in Xentry?
I just need to reset the ten restarts countdown while troubleshooting so perhaps I was incorrect to call this "programming."
Does Openport work with Vediamo? or do I need a more robust J2534 like a Autel Maxiflash or something like a C3 clone ?
I am open to either, but was under the impression that openport was ok for basic work. Although it appears you guys are not a fan of openport
What is your preferred device?
SPONSOR
WWW.BENZNINJA.COM
the ONLY complete device is a well selected C4 clone (95% of them have bad hardware) or a Original C6
with all the rest you will always get stuck somewhere then upgrade then upgrade until you finally listen
need to reach your wallet once in while. this is MERCEDES
SPONSOR
WWW.BENZNINJA.COM
forget about the Oem C6 its 1700-2100$ used and if the seller is a thief you'll get it banned
I point out that the clone C6 is junk for now
but good clones are available from some rare stores in China
I'll pm you some links
Benzenator (11-30-2020)
